02-19-2004, 12:27 AM
Confused???
have a few questions i need answered a.s.a.p im dying to try this out, thanks in advance.
1. What all is needed for the 5-cell setup?
2. any certain type/brand rechargeable batteries required/recommended?
3. where to buy rims ?
heres is what i have right now.im a noob so go easy on me .
stage 1 motor upgrade
AAA battery add-on for 5th cell
18 gauge wire (is this nessacery?)
02-19-2004, 10:26 AM
TinyRC XModder
1. For the 5th cell:
- Soldering iron, or gun (and solder)
- Some sort of quick disconnect that would work with your 18 gauge wire
- Hot glue gun
- Heat shrink tubing (highly recommeded)
2. Rayovac IC-3's are the battery of choice for a lot of people on this site, you need the charger to go with the batteries. RS sells IC-3's under their own brand name (more expensive though). I know that Wal-Mart sells the 4 bank charger, and I think the AAA's (they're pretty hard to find). If you had to, you could buy them online @ www.microcenter.com.
3. I assume you know that RS sells rims. Check out this site, at the bottom it has the e-mail of a guy selling aluminum rims.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
02-19-2004, 06:01 PM
ok cool , any advice on a quik connect setup? yea i knew about the rims at RS ,but i was wondering if there is any compatable ones from other dealers like Kyosho? also i read today that the starter kits comes w/ one stage 1 motor is this true? if so i think i wasted my money buying the stage 1 kit right?
02-19-2004, 06:07 PM
02-19-2004, 06:50 PM
The S1 motor kit will give you the option of running motors with different pinions for different gear ratios.
The starter kit only comes with a Stage 1 drift motor, which is the torquiest motor available from RS, also the slowest motor as far as peak RPMs.
I would say, your money wasn't wasted.
craftsman, on this forum, sells aluminum wheels compatible with Xmods. Find him and give him an email.
02-19-2004, 08:36 PM
TinyRC XModder
Actualy according to this post the stage 2 motor can spin faster and can make more torque than the stage 1. The only advantage is that the stage 1 draws fewer amps.
These quick disconects are the ones I got. There are better ones, like Deans connectors, but you have to get them online...I think.
For Mini-Z wheels you'll need to modify them to work. BC has a tutorial located here that describes how he modded some wheels he got at his LHS to work with his XMod.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
02-19-2004, 08:52 PM
alright thanks alot for the info.
02-19-2004, 09:28 PM
Meh, too much info to read - not in the mood at the moment :P
I don't see how a motor with so many more winds(85 compared to 49) will make less torque than a motor with far fewer winds. Given they are using the stock pinions. If the tests show otherwise(I didn't read through, nor open the pdfs), I would say one or more of the motors used were flawed.
02-19-2004, 10:33 PM
TinyRC XModder
The only other conceivable differences must be the wire gauge and/or the magnets.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
02-20-2004, 08:43 AM
Magnets are the same.
There is a wire difference, 32 on the S1s and 30 on the S2s. I positive thats not enough of a guage difference to put the S2 further in torque than the S1 considering the 35 turn difference.
02-21-2004, 06:45 PM
02-21-2004, 09:40 PM
TinyRC XModder
They might be a little big to fit under the car, but if they fit then use them.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
