01-26-2004, 08:36 AM
teenage r/c maniac
how can i fix this?
i have a lil problem. i was puting my cover on n then it started smoking!this happened to me 2 times . i have a 6 cells on this skyline. this is near the crystal
01-26-2004, 08:10 PM
TinyRC XModder
The antena must have touched a battery terminal. Unless it still works you need a new resistor...or PCB.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
01-27-2004, 10:46 AM
teenage r/c maniac
it still works but i have low range on my car . its like a feet away at the most. where do i get this pcb?
01-27-2004, 11:06 AM
TinyRC XModder
Name: PCB ASSY RECEIVER
Part #: 12414207
Price: $9.49
This is from CJ's XMods FAQ
Just go to your local Radio Shack and order it there, or call 1-800-THE-SHACK.
You will have to resolder 4 wires on the new PCB, it might be easier to get a new resistor and resolder it (or have somebody else do it for you).
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
01-27-2004, 06:46 PM
teenage r/c maniac
soo...........the burned part is a pcb or a resistor?
01-27-2004, 07:54 PM
Actually, its an inductor.
L2 = 0.82uH or 8.2uH (grey red silver) or (grey red gold) respectively
If you can solder, you can fix it without buying an entirely new PCB.
You may want to check out this thread in another forum. Click Me
01-27-2004, 08:27 PM
TinyRC XModder
So, what's the difference?
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
01-27-2004, 08:31 PM
The hell if I know  I'm just using the terminology found in the thread with the fix.
02-08-2004, 09:00 PM
teenage r/c maniac
does this work? instant mesege me [AIM]
02-09-2004, 07:03 AM
TinyRC XModder
 It looks like you just threw any inductor or resistor you found, and then soldered it to the wrong side of the board.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
02-09-2004, 08:15 PM
teenage r/c maniac
sooo.........now wat?i have no experienced wit this thing except soldering
02-09-2004, 08:20 PM
look for "Extended Range?" in the XMODS>XMODS section. there is a fix in there. and you have to try it. if you still have bad range try flipping the one you added around.
