Old 01-15-2004, 03:55 PM
food123 food123 is offline
Rough Rider
I just installed a stage two roadrace engine. When I took apart the drivetrain I noticed a yellow plastic piece (like the ones on the axles) floating around. I can't figure out where it goes. I continued installing and it runs. But I've noticed that it sounds rough. I'm afraid that this little piece got knocked out of place during installment, and is tearing up the insides.
Old 01-15-2004, 04:02 PM
xmodsman's Avatar
xmodsman xmodsman is offline
Send a message via AIM to xmodsman
well if it runs i guess you didnt screw anything up....that bad
blue RSX
wild silver body kit
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
custom plastic skidplate
white rims
metal lugnuts
mini-z tires
and custom painted chasis
Old 01-15-2004, 04:09 PM
true
Old 01-15-2004, 05:46 PM
theMonster's Avatar
Got Brains?
ahhhhh
I believe the piece you're referring to is the driveshaft's bearing and/or bearing carrier. The bearing metal or plastic fits into the yellow holder that's shaped like this: :-O-: and the driveshaft goes through the bearing. There's two screw-holes on the bottom of the car to hold the bearing carrier in place. I didn't put that part back together right the first time I took my car apart too.
This is your brain.....
Old 01-16-2004, 11:32 AM
yeah that's where I thought it went but it comes out everytime I run it, so unless it's hurting anything, I think I'll let it be. (putting it back together took a while lol)
Old 01-16-2004, 06:00 PM
theMonster's Avatar
Got Brains?
It may cause excess vibration on your drive shaft and/or may make it pop out of alignment with the gear that it meshes with. The car will stop running and you'll hear the motor spin but no go, then you'll be even angrier. I'd suggest putting it back on.
Old 01-18-2004, 02:34 PM
thanks
Old 01-18-2004, 04:24 PM
00black_civic 00black_civic is offline
I had the same prob i just bought the metel bearing upgrade and that fixed it. Its also alot faster.
Old 01-19-2004, 10:36 AM
i heard that the bearing install was a pain in the ol'a$$
Old 01-19-2004, 10:54 AM
neurokinetik's Avatar
Or worse, the driveshaft could contact the electronics, frying them...
Old 01-19-2004, 06:09 PM
how can I make sure that this won't be the case?
Old 01-19-2004, 08:17 PM
Make sure the bushings(or better yet, bearings) are in place and it won't happen.
Old 01-20-2004, 01:45 AM
codedat
When in doubt use electrical tape. Hehe. You can cover the PCB where the shaft is with it as a precaution. Oh don't cover the shaft itself with tape. (just a reminder)
Old 01-20-2004, 05:01 PM
so it won't hurt to tape the electronics?
Old 01-20-2004, 05:48 PM
newbitowner's Avatar
Today, I also had a piece of plastic break.
I don't know what it is either. The car runs the same.
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
i rider! zipzaps-freak Other Tiny RCs 3 12-12-2004 07:40 AM
My Knight Rider KITT with scanner ikinari Auldey (All) 7 08-14-2003 02:38 PM
Did anyone pick up a Knight Rider Yet? JBit Bit Char-G / MicroSizers 0 01-07-2003 02:49 AM
Knight rider bit is this true? Racemonster505 Bit Char-G / MicroSizers 23 11-10-2002 08:52 PM
