  #16
Old 12-28-2003, 12:17 AM
pbmax's Avatar
pbmax pbmax is offline
Li-Ion Addict
WD40 is safe for plastics, but it is more messy than using a something like graphite powder.
pbmax
Old 12-28-2003, 09:49 AM
QPizzle QPizzle is offline
Send a message via AIM to QPizzle
entirely way too messy..
Old 12-28-2003, 10:25 PM
Daazndood Daazndood is offline
is running without any lubricant or powder ok? thats what im doing right now.
Old 12-29-2003, 07:57 AM
neurokinetik's Avatar
Re: vaseline good for gears?
Originally posted by Daazndood
well, i have taken my car apart, and it was very dirty. i cleaned out everything. every last little peice. so now, its as dry as the sahara desert. it still doesnt have much friction due to the metal bearings which is a good thing, but the gears are loud and dont perform very well. i was wondering what i should use to lubricate it. i have alot of vaseline, but is that good to use?
I used to use Vaseline on my 1/10 and 1/12th scale cars. It's cheap, and works reasonably well. It does attract dirt, though, so regular teardowns and cleanings are required. It works fine for the gears if used sparingly. (Don't just gob it on) For the bearings, I use a lightweight oil.
Old 12-30-2003, 11:30 AM
teamdeadbunny's Avatar
teamdeadbunny teamdeadbunny is offline
Track Master
Originally posted by SKYHIGH
no they sell it at hobby shops in a little tube, its ground up like a powder and really works great
#2 pencil + nail file = graphite for gear happiness and no trip to hobby shop required. (the formula used by many happy pinewood derbys)
Old 12-30-2003, 04:12 PM
#2 pencil and nail file? sound good to me, but where exactly should i sprinkle this powdered graphite
Old 12-31-2003, 10:16 AM
Track Master
It's actually good for any parts that need to connect and move together including the gears, axels, etc.
Just be careful to clean any other lube that may already be there first. If you mix the graphite with other lube it will make a mess and reduce efficiency, thus negating the point of the graphite.
Old 12-31-2003, 12:44 PM
ok then, thanks everyone.
Old 12-31-2003, 01:08 PM
civic freak's Avatar
Tiny RC Guru
could you use yo-yo lubricant? ive got tons of that
Old 12-31-2003, 01:22 PM
Track Master
Isn't that yoyo lube just wax?
Old 01-02-2004, 11:12 PM
Rx7NoZ's Avatar
Rx7NoZ Rx7NoZ is offline
use cooking oil it would work perfectly
Xmod:
Civic (black)
Stiff Suspension
Awd
White side skirts,White Carbon fiber hood,White rims and Drop
Old 01-02-2004, 11:16 PM
dont use cooking oil. i used olive oil when i first got the car, not even alot, i used a toothpick, and after like 5 mins of run time the entire car was slimey and greasy and its a pain to get off. stick to dry lubes if at all possible.
Is building a motor out of parts a good idea? Bash_N_Thrash XMODS 4 01-26-2004 01:54 PM
is plywood a good track surface? if not, what is? and barriers,. whats good??? eman1 Tracks 6 07-21-2003 03:48 PM
Where Is a good place to get nice decals? Jr08bll Bit Char-G / MicroSizers 10 05-01-2003 01:03 PM
