Old 12-27-2003, 12:52 AM
FenderdudeRRT FenderdudeRRT is offline
stage 2 yellow bevel gear with Stage 2 red motor?
yea i lost my red stage 2 bevel gear but i really wanna use my red motor can it run fine still if i used the red motor with the SII yellow bevel gear? i dunno if its bad for my car but i just want to know i just returned my old defective skyline and got a new one now this one the atenna reception is horrible i lose reception after sorry 20 feeteven can anyone help? ST. RANGe is on max the antenna and crystals are all plugged in snuggly. Please help
XModS Gloss white Toyota Supra
SII drag motor
Wild style body kit with custom spoiler
Rayovac AAA IC-3 rechargables!
Eibach stiff and soft suspension
Tire Uprgrade
command lites
What is the Matrix?
Old 12-27-2003, 09:03 AM
RC 2NR RC 2NR is offline
TinyRC XModder
You could install it and see how if it rolls smoothly, its worth a try.
Have you tryed a new 9V for you controller?
Old 12-27-2003, 12:39 PM
I dunno i tested my 9v battery and its still in the good zone on my tester so i dunno im gonna go get another new 9v and see, if it still doesnt work, i wonder waht the guy at radio shack is gonna think when i return the car i just got that replaced my old one from yesterday
SII drag motor
Tire Uprgrade
command lites
What is the Matrix?
Old 12-28-2003, 03:04 AM
neurokinetik's Avatar
Re: stage 2 yellow bevel gear with Stage 2 red motor?
That combination may not work properly, but you should be able to use the white gear with the red motor. Just use the small washers from RS under the motor mount if it doesn't turn freely. Keep in mind your gear ratio will change. if you use anything but the red gear.
motor and gear problems... JojoPB Bit Char-G / MicroSizers 16 04-24-2003 01:32 AM
Report on Motor Swap in MS Pro..... DarkTari Bit Char-G / MicroSizers 7 03-26-2003 08:45 PM
Strange Observation, zip zap red motor in a 1 cell bit booster, and in a tricell. Clint Bit Char-G / MicroSizers 3 03-20-2003 12:58 PM
Motor Support Sub-Forum - Read This First! tinyrc TinyRC.com Motor Support 0 03-16-2003 08:38 PM
snapped a gear that goes from front motor to fromt wheels catman25 Mini-X 13 11-27-2002 12:26 AM
