Old 12-16-2003, 04:12 PM
targatop7mgte targatop7mgte is offline
Send a message via AIM to targatop7mgte
SBP motor help
okay i'm not a gear head in the sense of these little electric motors. i read a thread about using the motor from an SBP. so i went out and bought one. i thought it would be a direct drop in (wiring it up of course) but now i'm confused. i was reading some other posts. so my question to you guys is...
I have a SBP motor... NOW WHAT! what can i do to get a motor better then my stage2 drift that i'm currently using. i would like close to step by step instructions. HOLD MY HAND please. im not an electronic junkie. thanks in advance..
(also soon i'll be running a 5-6 cell power supply. will this need to be factored into the motor?)
Old 12-16-2003, 04:51 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
if you've dropped it in and got the brass gear onto the motor shaft then run it and see if you like it
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-16-2003, 05:20 PM
well thing is i haven't put it in. i don'tk now how to get the brass gear off. also do i just wire to the two prongs showing or do i need the resisters/caps like the namebrand motor has?
Old 12-16-2003, 07:09 PM
theMonster's Avatar
Got Brains?
tools
You need a pinion puller and press (about $8) to get the brass thingy off of one motor and back onto the other (or else you'll just ruin 2 motors). Also, you do need the caps/resistors in order to prevent radio interference to/from your motor. Get out your magnifying glass to read the #s on them and you should be able to pick them up at RS.
This is your brain.....
has any one tried the spin brush motor mod? stl2ner XMODS Parts and Hop-Ups 118 01-25-2004 03:04 PM
Faster in Reverse than forward? SBP Venom5.0 XMODS Mods and Projects 12 12-25-2003 07:40 AM
Need help with spinbrush! dEmOnRaCeR XMODS 29 12-19-2003 02:53 PM
sbp motor tests w/ results stl2ner XMODS Parts and Hop-Ups 19 12-05-2003 12:08 AM
