Old 11-29-2003, 01:38 PM
aperson's Avatar
aperson aperson is offline
Extended Range?
i think i may have found a way to increase the range without adding an antenna. if you look the where the antenna comes out of its PCB you'll see two green resistors. if you replace one of them with a bigger resistor it will extend your range. last night when one of them blew and the range went down to 3ft i was going to just jumper it with a wire but that made it even worse. so i took one out of an old radio and put it in and the range is at least back to what it was. i havent had anyplace big enough to drive it on yet cause its snowing.
Old 11-29-2003, 02:34 PM
security civic security civic is offline
sleeper mall civic
Send a message via AIM to security civic
hey u read my thread about the civic on fire, if it did short out can i just use the pcb (i think thats what it is) i took from a skyline
douglascounty!!!
Old 11-29-2003, 03:22 PM
aperson's Avatar
you could take the entire electronic system from the skyline if you want. they're all the same except for the "new" & "old" versions. check the crystal plug and whichever one sits lower choose that one.
Old 11-29-2003, 09:39 PM
sleeper mall civic
ok my wireing is totally f ed up so i cant use the sky part how do i replace one of those fuses (im not sure if that is what blew, how would i no)
douglascounty!!!
Old 12-02-2003, 08:43 AM
aperson's Avatar
if you take it apart and look at the little PCB where you plug the crystal in there should be two small resistors right next to where the antenna plugs is soldered on, if one of them is green and the other is black you have to replace the black one. take the entire system to some electronics store that isnt RS and ask someone there if they can find it. if they cant find it or cant order it take it out of the Skyline and replace it. or you could put any resistor in and it should work.
Old 12-02-2003, 10:36 AM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
what value of the resistor did you use? do you happen to know the resistance of the original one? (at work so i can't measure it myself)
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-02-2003, 11:21 AM
aperson's Avatar
im at school right now ill get home in about 3 1/2 hours. right now i have no clue what it is all i know is it works. and i can identify it by the colored rings on it right? i dont have anything to test it with. and i dont know what the original is.
Old 12-02-2003, 12:45 PM
TypeZer0's Avatar
0reZepyT
i think it should be the same color code as regular non-surface mount resistors
Old 12-02-2003, 04:55 PM
sleeper mall civic
well im not that much in a rush to get it fixed anymore cause RS is ordering me a new chasie and i hope the let me keeep the old one then ill get that fixed with the parts i got from and old sky and ill have 2 but with 1 diff crystal thanks for the help
douglascounty!!!
Old 12-03-2003, 08:22 AM
aperson's Avatar
entire new chassis? with electronics and all? how much did that cost?
Old 12-03-2003, 08:44 PM
sleeper mall civic
they should be giving it to me for free cause when i told her about my problem she said she would order one and didnt say anything about costing me anything (if i have to pay ill just tell her i cant and get her to hold it for me till i get enough money cause i got to get presents for the family)
douglascounty!!!
Old 12-03-2003, 09:31 PM
corysmith's Avatar
corysmith corysmith is offline
Fred Obando Rox My Sox
Send a message via AIM to corysmith
how about pics of the process
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
All at a 30% Discount, OORAH!
Old 12-04-2003, 08:16 AM
aperson's Avatar
im not really sure if it extends your range or not because i havent had anywhere to test the range except in my house from one end to the other. but thats through walls and ill have to take some pics when i get home
Old 01-07-2004, 03:33 PM
keeperman13
one quick question, it may be stupid but i doubt it.
when you guys are saying PCB are you guys referring to the cars PCB or are you calling the remotes circuit boards a PCB?
which device do i need to work on is what im asking here.
Old 01-08-2004, 08:03 PM
aperson's Avatar
the cars electronics. there is one large L shaped board and one smaller board where the antenna comes out of. thats the one im talking about. i havent heard about anyone having a fried controller.
ZZMT Remote Range 88-Fiero-GT ZipZaps Mods and Projects 1 10-09-2005 09:03 PM
Poor range kennylxix XMODS 7 12-22-2004 02:13 PM
My extended range mod ;x soggyrice.mMmMm Bit Char-G / MicroSizers 7 04-22-2003 11:13 PM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
