Old 11-08-2003, 03:02 PM
skklown skklown is offline
my lights are wierd
i took out the lights in my savannah to see if i could wire up 4 headlights. 4 leds takes up 2 much power but 3 leds up front work. so now i have a beam shining out of the right wheel well pointing out to the right. looks kinda kewl. but ever since i put them back in the car the tail lights also go on when i drive forwards and they go dim when i am stopped and when i am goin backwards. this isn't much of a problem cuz it looks like a real car now...but why are the taillights turning on when i go forward?
xmod blue civic ricemobile.
Old 11-08-2003, 03:14 PM
here is a pic at full throttle and goin forwards
Old 11-08-2003, 03:15 PM
here is the car when i am just sitting at a stop
Old 11-09-2003, 05:07 PM
anybody know y this is happening? does anyone elses lights do this?
Old 11-09-2003, 06:05 PM
viperkilla's Avatar
Hmm...I think that the LEDS maybe going bad. This never happened to my SE. If problems consist then return it.
Old 11-09-2003, 07:49 PM
i cant return the car....i modded the headlights so i would have 3 of them and now all the lights turn on....they seem to be fine as i have run the car for about an hour today(with charging every once in a while) i took some more pics. here they are. i also repostioned the 3rd light to the left side as a fog lite. here is the aerial view.
Old 11-09-2003, 07:50 PM
front view
Old 11-09-2003, 07:53 PM
back view with car at full throttle in forward
Old 11-09-2003, 07:55 PM
side view at full throttle
Old 11-09-2003, 11:11 PM
carlisimo carlisimo is offline
Send a message via AIM to carlisimo
What happens when you de-mod it?
Old 11-10-2003, 02:50 PM
i dunno...i soldered and taped the wires up
Old 11-17-2003, 06:29 PM
Lord_HelmetR34's Avatar
Lord_HelmetR34 Lord_HelmetR34 is offline
Bit Crazy
I would try reverting back to the stock light setup and see if that is the cause. If it isn't, then you should just mod the lights to run off a coin cell.
Dubshop Customs
Command Logic Lights MODS drewdown84 XMODS Mods and Projects 4 07-30-2007 01:33 PM
glow lights on car SkylineEvo XMODS Mods and Projects 0 11-12-2003 12:48 AM
running lights from car battery esp rocker Bit Char-G / MicroSizers 4 06-24-2003 01:23 AM
putting lights in my car xatu Miscellaneous Discussion 12 06-04-2003 12:06 PM
Lights and Bit Char-G DigitalAce7 Bit Char-G / MicroSizers 1 11-08-2002 03:45 PM
