Old 10-29-2003, 03:26 PM
crusader4x crusader4x is offline
Mini-Z Turbo
Have any of you other Mini-Zers tried installing an aftermarket turbo that we use on Mini-Z's into your Xmod?
Old 10-29-2003, 04:51 PM
TwizteD TwizteD is offline
Send a message via AIM to TwizteD Send a message via Yahoo to TwizteD
dident know mini z's had turbo??..how is that possible
Old 10-29-2003, 05:58 PM
There are many aftermarket turbos for Mini-Z's. Basically, you attach them to the batteries and the motor and they somehow bypass the stock ESC.
Old 10-29-2003, 06:54 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
It will likely work just fine. The XMODS work on the same principles as Mini-zs.
Oh, a "turbo" is actually an external motor controller, it has nothing to do with forced induction.
Old 10-29-2003, 09:23 PM
PhillyB PhillyB is offline
dont you lose reverse/brake with most turbos?
Old 10-29-2003, 10:32 PM
Nathan's Avatar
Bad Driver
Only some, the $30 "twin turbo" can be found at tower, and it has forward, reverse, and brake.
Old 10-29-2003, 10:41 PM
u think that would be possible 2 fit in the XMOD????
Old 10-30-2003, 04:31 PM
Chris's Avatar
Chris Chris is offline
Send a message via AIM to Chris
What kind of gains would a turbo give? more torque, top speed? Is it worth the $30?
Old 10-30-2003, 06:53 PM
Nathan's Avatar
Bad Driver
Yes, it would fit.
The turbo is worth it if you want to run a highly modified motor like those sold at minizracer.com. It will give more tourqe with normal motors due to less resistance and higher current limits. The speed may increase due to the low resistance as well.
Old 11-01-2003, 04:12 PM
Viper966 Viper966 is offline
Send a message via AIM to Viper966
Yes, it would fit.
ill be installing a p03 motor and turbo sometime next week
Old 11-01-2003, 05:33 PM
whats the po3 motor out of?
Old 11-01-2003, 10:57 PM
its a racing motor for the mini z's it has a ball bearing can and neo magnets... IE it goes REALLY fast
Old 11-02-2003, 10:47 PM
caan u get this at the hobby shop?
Old 11-07-2003, 01:31 AM
FLMX647 FLMX647 is offline
VIPER let us know how that motor works out
Links to Mini R/C Sites MicRoMaN Bit Char-G / MicroSizers 18 01-13-2003 01:55 PM
just about to order mini z or mini x but have a question tarnjit Mini-X 0 12-22-2002 09:01 AM
Mini Cooper Bit Char-g = A Lie Zakkorn Bit Char-G / MicroSizers 18 12-11-2002 05:05 PM
