  #16
Old 10-27-2003, 08:33 PM
Bad Company's Avatar
The holes in the discs are only slightly larger than the axle/pin to run thru. The brakes are glued to the outer part of the bearing housing. The wheels fit right into the little cup on the discs. I tighten the wheels and lugnuts not quite completely tight, but enough that there is no wobble. The brakes stay in place when the axles and wheels spin.
You have to use the "shallow" discs from the XS Tuning Kit, and shave the backside of the discs flat. Then drill out the centers slightly larger than the axle/pins.
Old 10-27-2003, 09:29 PM
PhillyB PhillyB is offline
so you cant change the bushing/bearings? hmm
Old 10-27-2003, 09:41 PM
Not without removing the brakes. I did this car mainly for show, and it already has the bearings installed. It will only be driven on the kitchen floor, so it probably will never need new bearings. I wouldn't install the brakes on my racer.
Old 10-28-2003, 03:32 PM
Spike88DS's Avatar
Spike88DS Spike88DS is offline
My MoMmY SaYs Im SpEcIaL
Send a message via AIM to Spike88DS
sory to get off the topic but, what does btw mean?
just say to your self when you get mad what would jesus would do....then say to your self wait y are you talking to your self
Old 10-28-2003, 03:58 PM
btw=by the way
Old 11-05-2003, 10:31 PM
FLMX647 FLMX647 is offline
Dang BC that is tight u r a smart sun of a gun.
BC EDIT: Removed innapropriate language and replaced with something more sutable.
Old 11-06-2003, 05:11 AM
Thanks for the compliments! Let's remember though this is a public forum, so please try to watch the language.
Old 11-06-2003, 05:57 AM
kingcobra kingcobra is offline
here's an idea...
I made the hole in the center of my brakes large enough to go OVER the bearing hub...and glued them to the outside of it...allowing bearing removal and not spacing the wheels out at all!!! you should try it...lot better!
Old 11-12-2003, 12:55 AM
Easymoney Easymoney is offline
Disc Brakes Mod
Howdy,
I also did a brake rotor mod to my Skyline. I used sheet lexan to make them out of. I traced the outline of a AA batt to get the right size. I'm not totally done with them yet. I only have two made at this time but am going to remake some new ones with calipers. Just made these ones really quickly the other night. Here are a few pics.
They are a little hard to see but they are there. I will post other pics when I get the new ones done. You can see more pics on my site and my forum. Later
Easymoney
1999 Red & Silver Nissan Skyline R34:
AWD, All RS Hop Ups, Tiny R/C Bearings, GPM rear outdrives and axle shafts
1999 Black Nissan Skyline R34:
AWD, All RS Hop Ups, Tiny RC bearings
1965 Blue Ford Mustang:
RWD, All RS Hop Ups
2004 Blue Subaru Impreza WRX STi:
AWD, All RS Hop Ups
2005 Blue Ford F-150:
Lifted 4x4, All RS Hop Ups
Old 12-04-2003, 05:53 PM
nobodyhere962's Avatar
nobodyhere962 nobodyhere962 is offline
Honda 4 life
Send a message via AIM to nobodyhere962
yo sup im not quite following bc i have no idea of the meaning backside
"Why do they have locks on the doors for stores that are open 24-7?"
that counts holidays too!
A new Question every year i think!
Old 12-04-2003, 05:57 PM
Honda 4 life
ok the brake pads look all tight and all but what kind of screw did u put on it doesnt look like the standard one that comes with the car
Old 12-04-2003, 07:03 PM
ZipRC's Avatar
ZipRC ZipRC is offline
Modder-Eater
Send a message via AIM to ZipRC
i don't think they're supposed to look like stock disc brakes.
Old 12-24-2003, 03:56 PM
Honda 4 life
no im not talking about the disc brake im talking about the screw that holds the wheels on
Old 12-24-2003, 04:04 PM
They are aluminum wheelnuts made for the RS4 and Mini Z's.
http://mini-zracer.com/shop/product.php?pid=443
Old 12-24-2003, 04:08 PM
Honda 4 life
oh they look alot nicer than the ones that come with the xmod
btw thanx for such a quick response
AWD with Resistor Mod for steering cool_cars XMODS Mods and Projects 20 12-04-2004 03:10 AM
disc brakes anyone? richh XMODS 3 10-18-2003 11:07 AM
Reverse mod..while keeping reverse ZIZI ZipZaps 4 11-26-2002 04:06 PM
