Old 08-27-2003, 02:05 PM
jono123
maximun #of cells????????
any1 no wots the maximum amount of cells i can use on my bit b4 it explodes
im thinging of adding an adittional 3 (thats four in total)
o and im setting themn up in a series for maximum speed if that makes a differenc.
o and will my motor burn out with 4 cells??(tomy 2.6)???????????
Old 08-27-2003, 02:56 PM
BabyKiller's Avatar
ok quad cells are fine any higher not fine. quad cells have been known to char somthiing on the pcb but thats rare and 2.6 probly wont burn out but putting higher voltage through it will shorten its like
+ (4.8v)
Old 08-27-2003, 04:32 PM
jono123
thx
i tried it 2 day with 3 cells on my superbit and it didnt run????????
im gunna wait till the weekend buy me a clone and 3 cell that
see if that werks
Old 08-27-2003, 05:22 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
The chips were designed to go no higher than 5 volts!
Old 08-27-2003, 05:34 PM
t-squared's Avatar
t-squared t-squared is offline
Bit Obessed...
I think that you should make a switch on the car for charging, since 4 cells would be 4.8v, and 3 alkaline batteries in the charger/remote - 4.5v, wouldn't be enough, you would need 4, which would make it 6v, which inturn might fry the PCB when charging. So I think you should make a switch which disconnects the PCB from the battery when charging just to be safe....
Old 08-29-2003, 12:29 PM
Daisycutter's Avatar
Daisycutter Daisycutter is offline
Cuttin' up Daisy
Aren't 4 cells just a wee bit heavy? Why don't you try a CR2 camera battery, they give 3V, and will give your car at least an hour of runtime.
Old 08-29-2003, 12:51 PM
BabyKiller's Avatar
to heavy not with all that power
+ (4.8v)
2 740mah Lipo cells and charger, $7.50 Jazz32 Miscellaneous Discussion 5 01-17-2007 11:25 PM
Thin Film Solar Cells, inspired by azimov Jazz32 Miscellaneous Discussion 5 07-23-2006 12:15 AM
Li-on AA cells Desslok XMODS Parts and Hop-Ups 30 04-13-2004 10:01 PM
How to charge the cells? miguellm Mini-X 3 08-26-2003 02:17 PM
double cell or single cell DeeChan Bit Char-G Mods and Projects 10 01-04-2003 06:38 PM
