Old 07-12-2003, 07:31 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
Arrow Weight reduction+lowering center of gravity
What have you done for weight reduction and/or lowering the center of gravity on your car? My idea is to make the chassis into a pan chassis, cut out the windows of my body, and somehow relocate or use a different battery. At first I thought of using one of the button cells like the ones for laymans dual cell, but then I read they couldn't put out much current. So now I am looking for a rechargable battery about the dimensions of a nickel. With a battery with those dimensions you could lay it flat in the chassis, therefore lowering you center of gravity. It would probably weigh less too. See ya later!
Old 07-12-2003, 08:30 PM
isk8blind's Avatar
isk8blind isk8blind is offline
isk8element too.
Send a message via Yahoo to isk8blind
your into micro rs4's arent you? umm you can cut out the sides of the chassis. and lay the pcb on the bottom of the chassis.
2 BCG nissan fairladyz
2 MS sport honda s2000
1 LXX auto modellista booster
and 3 clones & a pcb.
Old 07-13-2003, 11:28 AM
Master Debater
No, I'm not into micro rs4's. Why? Have you done any of those mods you are saying?
Old 07-13-2003, 01:11 PM
Master Debater
Does anyone know where I can get rechargable batteries about the size of a nickel?
Old 07-13-2003, 01:43 PM
Master Debater
Sorry for the multipost but I have another idea. What about wiring the layman dual cells in parrallel for more runtime, more current, and you could mount them in the bottum of the chassis for a lower center of gravity. They would be lighter than 1 regular battery too. Anybody with multiple cars wanna try this? I only have 1 complete working car.
Old 07-13-2003, 02:20 PM
DraGula's Avatar
DraGula DraGula is offline
TinyRC fool!
you could use the 3v cells used in the LED mod, but i dont think they'd work all that well.
I command you to: check out the site
Old 07-13-2003, 02:36 PM
Master Debater
Yeah, but I don't think those are rechargable.
Old 07-13-2003, 03:57 PM
PseduoRooter's Avatar
PseduoRooter PseduoRooter is offline
I hate suits!
2 layman's cells in parallel(sp?) would get you about 140mah. definately lighter than an aftermarket 140Mah in a single cell.
Old 07-13-2003, 06:34 PM
Master Debater
And they would lower the center of gravity, But would they deliver enough current to the motor?
Old 07-13-2003, 10:01 PM
isk8blind's Avatar
isk8element too.
i asked if you were into micro rs4's cuz you wanna have the lowest center of gravity with your car or itll flip going 30+mph. and yah ive done those mods
Old 07-13-2003, 10:03 PM
isk8blind's Avatar
isk8element too.
ohhhh yeah i thought of an idea. you could cut out the bottom of the chassis so the pcb fits in there perfectly then the COG would be lowered. i think.
Old 07-14-2003, 08:48 AM
Master Debater
Well if I cut out the bottum of the chasssis I can't cut out the sides and the sides weigh more and are higher on the chassis. I was thinking though and if I did the button cells in parralel i could put them flat on the buttom of the chassis and put the pcb right on top of it. My question right now is has anyone run the button cells in parrallel? How did they perform? Oh yeah, does anyone have pictures of these kind of mods?
Old 07-14-2003, 01:43 PM
charliebrown's Avatar
Actually two layman's cells would amount up to 80 mah. Now the ratio of minutes to mah is 9/10. So for Every 10 mah, you'd get 9 min if fully charged. So, using ratios, 9/10 and ?/80, divide 80 by 10 to get 8 and multiply 8 by 99 (edit: I mean 9) to get 72 min total runtime. Now, 36 min would be the FULL runtime of a layman's dual cell.
Old 07-14-2003, 02:21 PM
Master Debater
Have you read the laymans dual cell thread? If so, you should better understand my concerns. My main concern is current to the motor and that these cells don't deliver enough current for high rpm motors. That's why I want 2 of them in parrallel, mainly to deliver enough current and a little more runtime and a little less weight and a lower center of gravity.
Old 07-16-2003, 06:44 PM
Master Debater
Ok, i'm doing fullsize wheel mod tonight, so i'm gonna have to cut the chassis anyway. I'm doing some of these mods. I also got a skyline body set cecause it looks lower and is lighter. So tonight I am putting on fulllsize wheels, making the chasssis into a pan chasis and lowering/ lightening my clear skyline body.
Crazy weight reduction Thread Reaper XMODS Mods and Projects 7 01-10-2005 10:05 PM
weight reduction allahsone XMODS Mods and Projects 0 03-10-2004 02:05 AM
Weight Jtskty Bit Char-G Mods and Projects 10 12-14-2003 02:34 AM
weight reduction Impreza WR reX Bit Char-G Mods and Projects 46 02-08-2003 08:49 PM
weight reduction.....worth it? MTL Bit Char-G Mods and Projects 6 09-08-2002 11:12 PM
