Old 11-23-2002, 04:01 PM
microsizer microsizer is offline
Send a message via AIM to microsizer
3.0v Li-Ion cells
hi im just wondering how good is the 3.0v Li-Ion cell, how much is and does it improve performence? where can i get one?
Old 11-23-2002, 08:54 PM
Chris's Avatar
Chris Chris is offline
Send a message via AIM to Chris
same question here, but I know for sure that it would improve performance if it is 3.0 volts to the motor. thats more than a dual cell mod with two NiMH or NicD batteries! hey, dual cell mod with two Li-Ion cells and a 3.8 motor. I think you would have to add 3 ounces of weight to the front to kepp it down! but, yeah, where can you get one of these?!
Old 11-23-2002, 09:22 PM
Ovgron's Avatar
Ovgron Ovgron is offline
I own you
that would rule, dual li-ion cells with a 3.8 motor. You can but li-ion cells at online r/c airplane stores. Li-ion cells are used in micro airplanes (stick flyers, backyard flyers, slow flyers, etc) or airplanes that look like a balsa wind up plane.
1/8 X-Terminator
1/8 Thunder Quake
1/10 Nitro Blizzard
1/10 E.Stampece
1/10 E-maxx
1/10 Evader BX
1/12 Nitro Legends
1/12 Digger 2
Old 11-23-2002, 09:59 PM
Chris's Avatar
would they fit in a bit witout modification? are they the same size as a NiMH or NiCD?
Old 11-23-2002, 10:04 PM
Chris's Avatar
HERE YA GO!! I'm not sure of the dimensions of a bit battery though. HEY, ANYBODY KNOW THE DIMENSIONS OF A BIT-CHAR-G BATTERY IN MILLIMETERS??
Chris's Avatar
oops, forgot to add the hyperlink http://www.maxxprod.com/mpi-7.htm
Old 11-23-2002, 10:49 PM
so does any1 know the dimensions
ZZ blue honda civic
2.8 monkey rotor, 150 battery cell, tires stock. antenna mod
Old 11-24-2002, 06:53 AM
tarnjit tarnjit is offline
around 16-14mm length and and 9-11mm width
Old 11-24-2002, 11:01 AM
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
Send a message via AIM to Pojo
wow well i just put a 3v duracell in my car and it pops wheelies all the time
Old 11-24-2002, 08:31 PM
Coolmanmj Coolmanmj is offline
So will the li-ion bateries fit in the bit char-g's chassi? How much are they?
Pojo is that a regular battery you used (AAA, AA)?
And could u post pics of tour car?
Old 11-24-2002, 09:05 PM
Chris's Avatar
where did you put the battery, though? if you mounted it on the back of the bit, the extra weight might make it wheelie. or did the battery fit right where a normal bit NiMH or NiCD would fit? how much did the battery cost?
Old 11-25-2002, 02:16 AM
i think u guyz misunderstood ..... he said he put a duracell in his bit ... they are not li-on cells... they arent rechargeable.
2 740mah Lipo cells and charger, $7.50 Jazz32 Miscellaneous Discussion 5 01-17-2007 11:25 PM
Thin Film Solar Cells, inspired by azimov Jazz32 Miscellaneous Discussion 5 07-23-2006 12:15 AM
How to charge the cells? miguellm Mini-X 3 08-26-2003 02:17 PM
double cell or single cell DeeChan Bit Char-G Mods and Projects 10 01-04-2003 06:38 PM
