Old 04-28-2007, 05:14 PM
PittPenguinFan PittPenguinFan is offline
Exclamation ZipZap not working
I found my old ZipZap, a red Dodge (Viper?), in my closet(I haven't used it in atleast a year) and decided to see if it still worked. I turned on the controller, the light was green, and then put on my car on to charge. When I did, the light blinked red about 30 times, then turned a yellowish color. I put in on my table, but it wouldn't move and the lights don't work. The car is on (that was the first thing I checked). I assume it's not the AAA batteries, because the light on the controller works. Is there something wrong with the car?
Old 04-30-2007, 01:19 PM
rody rody is offline
Is this an SE? If so, you have to make sure to turn the car on on the bottom of the car before you put it on the charger.
Old 08-08-2007, 10:44 PM
silentgun919 silentgun919 is offline
Talking
umm read the manual cuz i read manual al da time it says that if the red light stops blinking, and the light turns amber (yellowish) it means there's a prob with the zip zaps. make sure it's on if it SE and make sure you connect properly lol i think that it but read the troubleshooting in manual.
Old 08-09-2007, 09:01 AM
fatman's Avatar
fatman fatman is offline
Thumbs down its gargege
i messed with it in yellow and it stalls if u take car off
if its not broke i can fix it
Old 08-17-2007, 02:10 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
I'd say the car's internal rechargeable battery is history. If you have another car, try switching out the batteries. Other than that, you'll have to find a source for a new battery for the car. The internal batteries go flat when stored for a long period and sometimes can't be recharged.
Old 08-17-2007, 08:50 PM
fatman's Avatar
noooo
dont id switch some parts lower chip and get a 150mah not 12o mah there cheap but semi hard 2 find
zipzap and zipzap se? xmod456 ZipZaps 8 01-24-2005 05:11 PM
just went through my parts box....... airbob20 For Sale/Trade 10 01-26-2003 12:21 AM
Zipzap motor and PCB dtmracer ZipZaps 4 10-17-2002 06:01 PM
BitDra-G reg. times for the ZipZap in! QFM Racing QFM Racing Customer Support 2 10-02-2002 02:09 AM
BItDra-G times recorded for 2.4v ZipZap QFM Racing Bit Char-G / MicroSizers 13 10-01-2002 10:15 AM
