04-07-2005, 08:55 PM
TinyRC Super Pro
driveline gear slippage
Hey is it normal for a monster truck to have driveline gear slippage?(when the front wheels are on the ground and the back aren't the back tires spin and the front don't and it makes noise) I have a orange motor and orange gears...so can anyone help me out????--PLEASE!
04-09-2005, 05:18 AM
thats never happened to me before.. but how are you getting your truck into this position? with the front wheels on the ground and the back wheels off?
I think, therefore I am not George W. Bush.
04-10-2005, 07:06 AM
zipped up tight!
maybe you're missing your dogbones?
04-10-2005, 08:02 PM
TinyRC Super Pro
slippage
i have no idea what dogbones are...and im holding the rear tires in the air and the front are on the ground and then it happens. thanks mike
04-13-2005, 12:57 AM
TinyRC Super Pro
slippage
I put some wd40 on earlier(before the slippageto fix a differnt problem) and I think that it made the gears slip easier. plus i have the fastest gears and motor which would probably make it slip easier...I THINK..not sure...any more tips people??? thanks
04-15-2005, 08:41 PM
TinyRC Super Pro
FIXED
Well I fixed it, my guesses were wrong. You know when you take the plate off in the back,the one with three screws with the axles under it, well turns out that the driveline gears in the back that make power go to the front were slipping because they werent making direct contact 100% of the time. well I took a piece of wire and made it so it pushed the gear out more(like a washer-looped) so it made direct contact,and it works! Im gonna lube it 2morrow so i dont cause damage-i probably wont tho.
06-22-2005, 10:17 AM
It's Really Fast!
Well, you're not supposed to hold one end still while revving the other end. That's what killed them in the first place. Mine are starting to slip, but I'm running a li-po with stacked fets, so that was expected.
Project Bad Brushless:
Just say no to giant sigs.
06-22-2005, 03:14 PM
TinyRC Super Pro
just to let you know, i wasnt holding it with two tires in the air and one tire on the ground when it broke. I was doing that when it had already broke, to see what was wrong
