Go Back   TinyRC.com > Miscellaneous Discussion
Old 08-07-2004, 12:31 PM
RacinSkillZ101's Avatar
RacinSkillZ101 RacinSkillZ101 is offline
Banned
Send a message via AIM to RacinSkillZ101 Send a message via Yahoo to RacinSkillZ101
Home Made Go-Karts
hey all, im lookin to build a one seater go kart, i want to acheive an at least 35 mph top speed, i am currently learning to weld, i have an idea on how to build a brake/ steeering system, but i have no clue as to what motor/ tranny/ gearing to use to acheive 35 mph+ their is a junkyard near my house and i figured i could pickup an ATV from them make it work and transplant everything to a custom frame, has anyone ever built a fast go kart?
the reason im so set on this is because my friend has a 30 mph go-ped with 3000 invested and im sick of him beating me on my mountain bike..
any links, info and tips would help thnx everyone!
Old 08-10-2004, 04:03 AM
micro kid's Avatar
Do you getto dremel?
35 mph is normal for a go kart. if you're going to use an atv engine i would recomend using its drive system as well. you can get 35 out of a 200 fourstroke easyly i'd suggest a full automatic though just for ease of use but if you want it really trick i'd get a manual clutch motorcycle engine. if you can get an atv why not just ride that? that would be helpful to give you suspension power, steering and brakes. they you just have to adapt that stuff if you really want a kart.
Old 12-16-2004, 07:45 PM
SupraKid89's Avatar
SupraKid89 SupraKid89 is offline
Anarchy 4-Ever!
Send a message via AIM to SupraKid89 Send a message via Yahoo to SupraKid89
go with a 5hp Briggs and 10 tooth clutch and get a low tooth sprocket for the drive wheel. U can probably get a go kart frome from a junkyard... besure to keep your wheel sprocket lined with the clutch or you'll have horrid chain problems...
Flat Black Supra
-Engine
Stage 2 Drift motor
-Exterior
Flat Black Custom Paintjob
Blue EL wire underglow (ordered)
Command Logic Lights (x2) foglights & extra taillights...
5Zigen Wheels
-Other Mods
AWD
Old 01-04-2005, 11:01 PM
Shingo420 Shingo420 is offline
Send a message via AIM to Shingo420
I SUGGEST A CR 125 KART ENGINE (i race go karts and cr-125's get 50 hp =D and i hav a 125 and it goes up to 120 but at the track ussually 85 mph) or get a kt100 engine (look on ebay) engines vary in price though and its not cheap (but alot of a ha
Old 04-26-2005, 12:24 AM
micro kid's Avatar
even a modded CR125 engine is only going to net something in the upper end of the 30's for horse power. A 250 is 50 horse easy but a 125 isnt going to be close.
Old 04-26-2005, 01:02 AM
ok, i got this in an email, but btw they DO get 50 hp, ididot i race them i know ill give you a site on KARTS Swedetech is the LEADING TOP OF THE LINE engine rebuilder, producer making 50 hp and btw the cr 250 twin piston in go-karts gets 90-100 hp the go-kart leagues spend SO much time on the engines YOU HAVNT HAD A CLUE! lol
http://www.swedetechracingengines.com
they dont talk about hp but they are the Co. that makes THE best engines, my friend won skusa (skusa is like national championships) with a SwedeTech
http://kartweb.com/Standards/ShifterStandards8-24.htm
talks about suggested rules/standards NOTICE it said Peak HP can be misleading, cause in a kart, it will jump an extra 5 hp or so for like 200 revs and it red lines 14,000 so that extra power people dont include, sometimes and it has 6 gears....
if you do get a cr 125 engine, make sure you give it 50 minutes of breaking in, keeping it in the 8000 rpm or lower to break it in
Home made disc-damper "Black Fiberglass?" Marcro Kyosho dNaNo Parts and Hop-Ups 6 07-22-2008 06:12 PM
Paper Bird 1 (home made bit plane) Comrade_Boris Micro Flight 10 10-27-2003 09:20 PM
Home Made Charger- Looks Good ..Wont Charge Suntzu28 Bit Char-G / MicroSizers 5 01-06-2003 10:55 PM
