Old 11-06-2003, 09:05 PM
rkk rkk is offline
Noise
So, I have seen plenty of posts about how loud the XMods are (can be), but I haven't seen any feedback on sugestions to try and quite the drivetrain. Some one mentioned graphite and powder teflon. Has anyone tried it yet? How were the results? Any other suggestions?
Old 11-06-2003, 11:02 PM
Got 4.2 King? I do : )
after lubing my bearings with some oil from the bearings i bought for my hockey skates it seems to have quieted down
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 11-07-2003, 11:02 AM
aperson's Avatar
aperson aperson is offline
put ball bearings in it and lube the drive train with something. the ball bearings will stop most of the vibrations in the drivetrain and should give you a little mor power because the vibrations are gone.
Old 11-07-2003, 12:04 PM
neurokinetik's Avatar
Alot of the noise is due to excessive friction between the motor pinion and idler gear. I shimmed my motor up slightly, and it had the benefit of both reducing the noise, and reducing drivetrain friction (making my car faster). I just used a couple of small washers that I had laying around.
Squeeling noise from inside. zipinzapin ZipZaps Monster Truck 19 03-06-2006 06:03 AM
Screching noise striker289 XMODS 16 03-03-2004 05:03 PM
xmods steering noise question JebusKrist XMODS 12 12-27-2003 11:23 PM
Booster Chassis - Grinding noise razardica Bit Char-G / MicroSizers 4 12-21-2002 09:04 AM
OEM Bullet makes a lot of gear noise, can i grease it up??? SPEED Bit Char-G / MicroSizers 1 08-22-2002 06:52 PM
