Old 11-05-2003, 10:12 PM
ZZ_King ZZ_King is offline
battery size
i was wondering what size the se batteries are in the zz se. i just want to know because most likely if I pop open the pcb ill break it . and im about to order some stuff from toyeast. and want to know if the batteries that fit in zzs fit in zz se.
Old 11-07-2003, 12:29 AM
tcg23 tcg23 is offline
Send a message via AIM to tcg23
I took my SE apart, no big deal, just be careful with the wires.
If you unscrew the U shaped plastic piece on the front and the piece of plastic that the antenna goes through on the back, you can CAREFULLY lift the PCB up.
The battery is a 2.4v 70mAh, GP or GE is the brand, forgot what exact brand though.
I want to upgrade mine to a higher mAh, just need to find one.
Hope I helped,
-TheComputerGuy23
Old 11-07-2003, 05:14 PM
thanks but I sont think you can find a battery with higher maH that still gives out 2.4v usnless you do a dual cell
Old 11-07-2003, 07:55 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
They actually have 2 1.2volt 70ma cells in the shrink wrap, for a total of 2.4volts. They are about 10mm long, standard Zip Zap/ bit batteries are about 15mm long.
That's all folks!
Size of SE Battery MicroSpeed ZipZaps SE 2 06-23-2004 10:14 AM
Battery Size crusader4x ABC DTM X4 0 12-15-2002 12:15 PM
battery size cfactor Bit Char-G Parts and Hop-Ups 2 10-21-2002 07:22 PM
