Old 05-21-2003, 12:08 PM
Tillek Tillek is offline
Angry Steering that refuses to be fixed
Here's my problem, my tomy bit turns very tight right, but horribly left. I've done everything I can think of to fix the problem: Cleaning the knuckles, replacing them, new steering spring, two steering springs, making sure the magnet is centered, different suspension bar, no suspension bar...
I noticed that the steering coil on the right side has one of the wires sticking out a little, hardly noticable though- no more than one wire width. The only other thing I can think of to do would be to go to radio shack and do the three rare earth magnet mod so that the magnet is larger than normal.
Is there anything I'm forgetting? The bit didn't used to do this, so at least it wasn't hosed from the start. Thanks!
Old 05-21-2003, 01:06 PM
Awaken's Avatar
Awaken Awaken is offline
Feh
Send a message via AIM to Awaken Send a message via Yahoo to Awaken
take off your back wheels and see if the wheel on the side away from the gear rolls without the axel...if so superglue it on and it should help
Give me a moment in which I well never AWAKEN
Old 05-21-2003, 01:15 PM
Yea, I checked that too. Just forgot to mention it. It's as tight as a... um nevermind. ;D Any other suggestions? Or must I live with a gimpy bit?
Old 05-21-2003, 01:18 PM
Awaken's Avatar
Feh
other then that i think you did it all...did you see if the plastic shock is touching the steering to hard? it wont turn right if it is on there to hard
Old 05-21-2003, 01:21 PM
Awaken's Avatar
Feh
ah never mind i over read that part you tryed that too...blah i have no clue unless the left coil is broken some where
Old 05-21-2003, 01:27 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
is this a bit or a clone? ive had clones that just wouldnt steer nomatter what i did.
id take a larger magnet and just kinda sweep it allover the whole front end to remove any metal dust.
Old 05-21-2003, 01:34 PM
dabigpig's Avatar
dabigpig dabigpig is offline
Awaken- please refrain from double posting very short posts. instead please use the edit function of the fourm and add on to you're original post to instead make it longer. it gets annoying to read double posts. thx in advance.
Tillek- well sounds like you've nailed pretty much everything i can think of there isn't much else that could be contributing to the problem that you haven't allready tried.
*** AMC Veteran ***
-- ^-_-^
Old 05-21-2003, 01:39 PM
Awaken's Avatar
Feh
opps guess im not used to cramming all my info on one post.hehe ill try to stop doing that its just a habit...kinda like talking in a chat room...you dont usually make long sentances and stuff.. will anyway you should try to take it back and get a new one..did it come out of the box with messed up steering?
Old 05-21-2003, 02:03 PM
Lol, I wish. I've had it for a while and modded the heck out of it, it's been fine until just recently. I think I got it from ebay or toy east anyway.
I'm heading to radio shack sometime soon, I'm gonna try changing the magnet out for 3 rare earth magnets put together, it makes the magnet a little thicker than before, I'll let ya know how it turns out.
Hogjowlz- you have a disturbing name... I never realized it until I typed it. It's a tomy fairlady z. thanks for the suggestion!
thanks for your help guys!
Old 05-21-2003, 02:55 PM
hogjowlz's Avatar
thanks. id just buy an mssport and swap out the chassis.
Ideas on how to increase steering power mde Bit Char-G / MicroSizers 4 05-01-2004 02:42 PM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 12:16 PM
Steering Help ZipRC ZipZaps SE 1 09-21-2003 09:57 AM
fixed the steering! mcharles13 Bit Char-G / MicroSizers 0 01-23-2003 12:28 AM
