Old 10-16-2002, 01:03 AM
natedogg4674's Avatar
natedogg4674 natedogg4674 is offline
Ill choke slam you!!
bought microsizer..swapped pcb's w/zz
I went to my local hobby shop and saw that they had several new microsizers in, well they use to want $35 for them, but due to poor sales the guy gave me one for 25. the speed was awesome, i must say it ruined my outlook on zip zaps, but i missed the look of the zip zaps, and the handling, so i said screw it im going in, after some serious tweakin and modding i got the boards and motors swapped. Now my zip kicks a** if you know what i mean. Im gonna take some pics and post the way i did the board, its so clean it looks like it came that way. And while I had it apart i soldered a new antenna on, a single strand of 10 guage wire, then ran it through the snap thing on the plastic cover, melted it together so it would stay there, superglued some shrink tubing to the body to feed the wire through so it wouldnt flop all around, i love the speed, and i actually think the cotroller is a little easier to use, oh yeah, i had to mod that a little too so it would charge. i clipped a little of the plastic nub that sits right above the charge tabs so the zip would go far enough down to enable the charger, im gonna try to get another board and motor from a broken microsizer so i can do all the same to my other zip, im spoiled now, wont go back, the stock micro was much faster than my red, or nos motor with any of the gear combos, So im running a 49 mhz zip, with microsizer stock board and motor, red gears, also using the micro battery too. I have 7 bodies to choose from, all the tires, hubcaps, and gear sets, so im set for awhile, anyone with a spare micro board, its well worth the trouble. back tomorrow
Old 10-19-2002, 01:59 AM
marc515192's Avatar
marc515192 marc515192 is offline
ZipZap Maniac
Send a message via Yahoo to marc515192
Thumbs up Did mine too!!
All I can say is
Couldn't believe the diffrence.
1999 Super Modified Zinc Yellow SVT Mustang ZZ
Bit PCB MOD
It's a sleeper! hehehehe
M/S Mitsubishi EVO Lancer w/modified clone motor
M/S Nissan Skyline
M/S Honda S2000
Old 10-19-2002, 11:06 AM
catman25 catman25 is offline
alot better than the reverse mod???im not to impressed at all with the zip zaps...im running a 3.8 mottor but still there is a difference between the bit and zip...you can hear and see the differance..if i put the bit board in the zip board would it make the zip just as quick ...got a free chassis from microsizer comming so i may switch ..:-)
Old 10-19-2002, 11:50 AM
marc515192's Avatar
ZipZap Maniac
Exclamation Way better than the no reverse mod
This is the way to go!
Handles better than a bit at high speeds almost instant top speed. Made mine so the zip controller works so looks stock till I hit the juice.
Well worth doing this mod and after this mod addind LED's is a snap because this PCB is so simple. I did mine last night so later I will and some tips and pic's
Bit PCB MOD
M/S Nissan Skyline
M/S Honda S2000
Old 10-19-2002, 03:44 PM
so the 27 chassis will work with the 27 mhrz zip ???the zip controller will work ??
yes pics tips and hey ..why not just do it for me ..j/k .//but all the help would be a help thanks
Old 10-19-2002, 04:30 PM
marc515192's Avatar
ZipZap Maniac
Lightbulb It will work
Yep a 27mhz bit PCB will work in a 27mhz zip.
The most important tip is to TAKE YOUR TIME!
1st I opened both PCB covers a looked very carefully to see wire configs. then I made a small drawing of the bit board and marked all wire colors on the drawing so I could refer to it during assembley. Pay attention to the layout on the bit PCB the only wires that are diffrent colors are the motor contact wires. Remove the wires from the PCB (Bit PCB first) and have the Bit PCB ready to install before removing the wires from the Zip PCB.
The one step I was very careful on was when I removed the +red wire from the zip board(there is also 2 steering wires here) I imediatly soldered the 2 steering wires to the red wire to make it easy to install to the bit board without having to guess which wire went where. This mod is very easy with a little patiance. I soldered the motor wires last because I reversed them so the zz controler fwd and rev were correct. Thats all there is to it. I did not have to change steering coils or contacts just the PCB's.
Things you will need
15watt solder iron low heat so not to add too much heat to the PCB.
Tweezers to hold and control the steering wires
And thin silver bearing solder
If anyone is good with tech. drawings and can provide a layout of both PCB's I'll add touching points
Bit PCB MOD
M/S Nissan Skyline
M/S Honda S2000
Sold Pro Microsizer Bought A Normal One 2G2SILVERSTRAT Bit Char-G / MicroSizers 5 07-04-2003 10:31 PM
Purchased 4 knock offs, 1 Microsizer on 5 freqs / results. AceQ Bit Char-G / MicroSizers 1 10-14-2002 11:49 PM
