Old 01-06-2004, 11:53 PM
NOS man's Avatar
NOS man NOS man is offline
SHYMERLOO!!!!
Send a message via AIM to NOS man
yo MR. bIgsHot. how did u get the pinion off the motor?
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
Old 01-08-2004, 01:15 PM
Mr BigShot Mr BigShot is offline
TinyRC PRO Modder
Eazy To Do
Just use a pinion puller . You can get them at your local hobbie shop or order them off the web .
Old 01-08-2004, 04:10 PM
NOS man's Avatar
SHYMERLOO!!!!
k but i need a way i can get it off without a puller
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
Old 01-08-2004, 05:24 PM
tavisjohn's Avatar
tavisjohn tavisjohn is offline
RC Tinkerer
A Puller is the only safe/reliable way to remove a pinion. There are other methods, however you could remove it by force, but you run the risk of ruining the motor you are removing the pinion from. Some have posed that if you heat the pinion you may be able to remove it, but no one has claimed success with that method yet. I'll be getting a pinion puller myself. (Unless I can find some replacement pinions)
Old 01-09-2004, 03:42 PM
NOS man's Avatar
SHYMERLOO!!!!
ok thanks but if anyone has any ideas, tell me...
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
Old 01-09-2004, 07:13 PM
TinyRC PRO Modder
Talking Sweet
Glad to See I made it in the Science section I have messed with my Xmods in a week cause I've been buzy buyin a new car I got a Honda Element <--- looks like a Mini H2 Hummer
Old 01-19-2004, 06:19 PM
TinyRC PRO Modder
Improved Second gear holding set up
I improved my set up for holding the second gear It's not done yet , but I have been so buzy . With this set up I think I might be able to get some real small bearings to hold the second gear shaft too. I also have a few more idea's for some pretty cool stuff in my head but haven't had time to produce anything yet
Old 01-19-2004, 06:45 PM
neurokinetik's Avatar
Looks promising. Keep those ideas coming...
Old 01-20-2004, 02:05 AM
3series takumi's Avatar
mini-eX-Driver
what are you doin about the gear ratio though, the 180 motors are not that much faster than 130 but they have loads more torque. you could put that extra torque to use
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 01-20-2004, 05:29 AM
Cian's Avatar
Cian Cian is offline
Got Cheese?
That big TO motor, is that the same size as a speed 300???
Lisa: And vice versa...
Old 01-20-2004, 11:19 AM
Cyslyde Cyslyde is offline
Re: Big Block in car
Originally posted by Mr BigShot
Here's a pic of my Big Block in my car still not done yet having a problem with when I turn my car on the servo turm s to one side and dosent work . I have to look at it later tho wife wont let me right now
did you ever fix this? I am having the same problem, but haven't had time to tear that car apart... if i know what i'm looking for will help out alot
thanx
-=Cy
Old 01-20-2004, 02:15 PM
TinyRC PRO Modder
Thumbs up Yes I Did
It was a loose wire on the servo I just resoldiered it .
Cian - Yes i belive it is " my big Block " I'am also installing The 45t in a car right now"for someone " its a little smaller.
Hey 3 series takumi - What you mean about gears I'am using a 11 tooth with my BB and a 8 tooth with my buddy 45t ANY susgestions you have will be "great" I haven't been messing with RC for that long only since the Xmods came out
Today I went to the local Kar Tunes <--- car audio installation shop to get some more wire and they give me a great way to make your power cables look SWEET !! You just take one black wire and one red wireand put one end into a vice "tight" Then you take the other two ends and put them together in a drill . Hold it tight and spin it and walk towards the end in a vice It braids it up real nice
Old 01-21-2004, 02:17 AM
man i havn't seen anybody twist wires like that for awile hehe your right that does work great tho. and thanx about that wire, which one was it specifically if you remember?
Old 01-21-2004, 03:10 PM
TinyRC PRO Modder
Twin Relay Mod made with RS 5vdc relays
This is the diagram that I used . I got it from a guy named Chino over at xmodrc 's forum . He is a proud member of "DSR" Drunkin Style Racein. To make it eazy what this does is let you run around 5 volts to your circuit board and any where from 10 to 12 volts to your motor Oh yea and if you want to go with more Volts you can add more batt's , but I useing 8 AAA's right now and you don't want to really go any heavier.Oh yea almost forgot I have the thing all wired up and this thing flies now I just haved to get 8 cell's under a RSX body Here's some pics
Old 01-21-2004, 03:11 PM
TinyRC PRO Modder
Pic of Volts going to Circuit Board
5.30
NML and Redline both need FET upgrades? SuPrBuGmAn XMODS Parts and Hop-Ups 6 01-05-2004 02:06 PM
Mini-Z Comparing CharlzO XMODS Gallery 49 12-11-2003 02:38 PM
Upgrades? cashdog144 XMODS Parts and Hop-Ups 16 10-30-2003 08:52 AM
NEw upgrades dEmOnRaCeR XMODS 5 10-19-2003 11:50 AM
upgrades jbach39 ZipZaps SE 1 09-22-2003 01:27 AM
