  #16
Old 11-28-2003, 08:07 AM
MattH's Avatar
MattH MattH is offline
2Fast4U
Send a message via AIM to MattH
The stock bearings are heavily greased and they also happen to be open or non-shielded bearings. The problem with the grease is that it is so thick it actually slows the bearings down and dirt also sticks to it which will cause the bearings to seize. So, the degreasing of the stock bearings provides to advantages: the bearings will spin much faster (your car will be faster) and, two, they will be much less likely to seize up.
Old 11-28-2003, 12:22 PM
xmodsupra xmodsupra is offline
cool ill grab some stp at work
Project Supra:
97 Supra
Black, Red hood
Mountain Dew skid plate
Custom Spinbrush Motor (11T/blue gear)
Custom 5th Cell System (9V)
Stock tires, superglued (didnt help)
Light kit
Wild body kit
more soon
Old 11-28-2003, 09:20 PM
MattH's Avatar
2Fast4U
I just realized I misspoke in my last post. When I referred to the "stock bearings," I meant the RadioShack XMODS upgrade bearings--as opposed to an aftermarket set from some other company. There are actually no stock bearings in the XMODS. The XMODS come with plastic bushings.
Old 11-29-2003, 09:42 AM
Freedom Rider's Avatar
Freedom Rider Freedom Rider is offline
Send a message via ICQ to Freedom Rider
Re: Vaseline?
Originally posted by viperkilla
I seem to be running out of the gear grease that comes with the AWD kit. Would it be okay to use vaseline instead? What else would be good as gear grease?
Don't use vaseline. If it gets cold it will harden and mess your car up. I didn't use the grease either because anywhere you race, you're bound to have dust or dirt. And grease likes to attract dust and dirt, thus screwing up your gears.
Freedom Rider
Nissan Skyline R34 GT-R V*spec
Wild Hood (Carbon Fiber)
Wild Bumpers (Painted Flat Black)
Wild Skirts (Painted Flat Black)
Mild Spoiler
AWD
Rubber Tires (Hard Treads)
Enkei Wheels
Aluminum Lug Nuts
Command Performance Lights
Stage 2 Motor (11 Tooth, Speed)
Suspension Uprade (Medium in Rear, Stiff in Front)
Steering Upgrade (3 Degree Tie Rod)
Metal Bearings Upgrade
Crystal Upgrade
XMODS Controller w/Sparco Wheel
Rechargeable Battery Kit
Old 11-29-2003, 02:23 PM
SonicKuz SonicKuz is offline
Send a message via AIM to SonicKuz Send a message via Yahoo to SonicKuz
But there shouldn't be gears in the ball differentials for the AWD kits (I don't own one though). Inside the differentials there are very small planetary gears or balls that kind bind up pretty easily, and they are not exposed like a pinion gear would be. Plus the grease can slow down the action if you want.
What goat?
Old 11-29-2003, 02:33 PM
aperson's Avatar
aperson aperson is offline
its ok to grease the differentials but make sure to put a little in the ends to attract any dirt/dust so it doesnt get inside the diff.
Old 11-29-2003, 09:29 PM
Lucid Dreams
the diff. that comes in the awd kit is ball bearing
vaseline good for gears? Daazndood XMODS Parts and Hop-Ups 26 01-02-2004 11:16 PM
