Old 04-07-2003, 10:18 AM
T_T_52
Quadra Steer
Souds crazy but has anyone done four wheel steering and still have the rear wheel drive. turning would be sharper
Old 04-07-2003, 06:09 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
You could take the front off another chassis and hook it up to the rear of a chassis, and you got 4WS, but also have some extra tires there....
Old 04-07-2003, 09:32 PM
MrMikey83 MrMikey83 is offline
Send a message via AIM to MrMikey83
I believe it would be possible. Like Xatu said, take the fronts of two cars and make them one. Only problem would be providing power. Would have to use very small pivot shafts like found on real cars that have independent suspension. Hey that's another thing, if you had fronts on both ends, it would be four wheel independant suspension. Also, if you put motors on bother ends, it could be four wheel drive. Slap some bigger tires on it and you have an ATV. I wonder if two motors would be enough to lift it up over rocks...
~Mike
Old 04-08-2003, 10:08 AM
T_T_52
I was thinking of a flex shaft but the joint axle would do beter. Thanks for the four wheel drive idea because I know how to use a slot car gearing.
making your car steer way better for 0$ rydzjunior XMODS 2 11-03-2006 09:13 PM
EVO Lift kit Bump Steer offroader_10 XMODS 6 11-02-2005 08:18 PM
My car wont go, but it will steer, what is the problem? chrishidalgo XMODS 0 07-10-2005 05:50 PM
how to make your mt steer like a dream in 30 sec micromatch ZipZaps Monster Truck 4 12-26-2004 09:07 PM
bump steer holshotracer TTTT 9 06-20-2004 12:48 PM
