Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer Parts and Hop-Ups
Old 03-18-2003, 07:48 PM
casper975 casper975 is offline
Fast's Motor
What is the best or fast's motor I can use with the stock ESC. I have a micro rs4 stock 180 motor in it know and I still want more speed out of it, if you have any info please reply, thanks
IF SPEED KILLS I WOULD BE DEAD BY NOW
Old 03-19-2003, 11:50 AM
motor
I think Im going to go with the Orion Core micro modified motor, will my stock ESC. handle it and what size pinion should I use
Old 03-19-2003, 12:59 PM
2000-redrider 2000-redrider is offline
You shouldn't have any problems with your stock ESC. I'm running the Peak modified, which is similar to the Orion Core, and I haven't had any problems.
I would suggest getting a few different pinions. Anything from 8T - 15T, that way you could switch to accomodate different track sizes. If you had to pick just one though, I'd go with a 13T.
Old 03-19-2003, 03:44 PM
motors
Ok man thanks for your advice, what kind of batts. do you use and how long do they last with your motor, I also have a bunch of 1/24 slot car motors I have a custom group 12 I built it has ballbearings and adjustable timing and it will hit 80mph in my drag car on the track but thats with 12volts running to it
Old 03-19-2003, 06:06 PM
I'm using an 7.2v aaa pack (1600 mah). I get at least 30 min on a full charge. It probably goes a longer but I haven't really timed it.
*edit - 600, not 1600 mah - sorry
Old 03-19-2003, 07:20 PM
Ok all I have is 4 700mah AAA's
Real Motor Analysis backtrack9 XMODS Mods and Projects 8 02-05-2004 08:13 PM
Measuring Motor RPM backtrack9 XMODS Science 9 01-12-2004 05:00 PM
(LONG)Another Motor To try "Nurelco Mustache Trimmer" Cyfiawnder XMODS Parts and Hop-Ups 25 12-19-2003 01:01 PM
Motor Support Sub-Forum - Read This First! tinyrc TinyRC.com Motor Support 0 03-16-2003 08:38 PM
