Old 03-17-2003, 11:52 PM
RabieS's Avatar
RabieS RabieS is offline
Send a message via AIM to RabieS
pcb swap ?
Ok, I have tried this once and failed. I can get everything but the tiny steering wires. How do you go about soldering those little things? I dont know how to get them where they go and all. How do you tell them apart ?
Old 03-18-2003, 10:50 AM
zclonedude's Avatar
zclonedude zclonedude is offline
i've no idea whats goinon
You carefully have to seperate right from left. There is no positive or negative. GENTLY scrape off the coating on the ends of the tiny wires. CAREFULLY heat up the small blob of solder on the pcb and with tweesers push the end into the blob and hold it there a second until the solder dries. The less heat the better. I'll attach a pic that might help!
Old 03-18-2003, 10:56 AM
zclonedude's Avatar
heres a better pic
Bit Char-Q: IR PCB swap Namuna Bit Char-G / MicroSizers 8 04-15-2003 10:44 PM
What is the best pcb swap? drft240 ZipZaps 17 01-26-2003 07:12 PM
racetin PCB swap with racewin project MTL Auldey (All) 15 01-18-2003 10:29 AM
Pcb swap/transmiter swap sessiz10 ZipZaps 13 12-04-2002 10:38 PM
PCB swap tips Bunta ZipZaps 0 10-23-2002 08:57 PM
