Old 02-26-2003, 03:00 PM
neoGTR22
Will this work as a peak charger?
My cousin gave this to me. Just curious if anyone knew if it'll work. It's a Hobbico 905 Multicharger. I found someone selling it on Ebay with a good description. I want to use it on my bits done with the layman's 2 or 3 cell mod. Thanks in advance!
Click here to see it.
Old 02-26-2003, 03:02 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
no it only plays ac/dc songs
any power supply that has an adjustable output should work.
Old 02-26-2003, 03:07 PM
neoGTR22
=P So I guess not then? At least I don't think u can adjust the output. I guess my other question then is; what's a good peak charger to use? Asides from making one. And my last question, what's trickle charging?
Old 02-26-2003, 03:13 PM
hogjowlz's Avatar
a waste of time and money.
your best bet is adding a 3rd battery to your controller or here this charges a dual bat. requires soldering but its not really that hard to do. also yes it has adjustable output thats what the knob is.
heres the link
Old 02-26-2003, 03:25 PM
neoGTR22
I made a charger for em already I just wanted something that:
1. Didn't need batteries.
2. Adjustable voltage output
3. Could "Auto-charge" the batteries ...if that's even possible.
btw ...I think the knob is a timer?
Old 02-26-2003, 03:47 PM
hogjowlz's Avatar
search on ebay for "variable power supply"
Old 02-26-2003, 04:19 PM
Namuna's Avatar
Namuna Namuna is offline
3v-12v @ 800mA
$15.99 at Radio Shack
Old 02-26-2003, 04:51 PM
hogjowlz's Avatar
does it play back in black?
Old 02-26-2003, 04:59 PM
dustn's Avatar
dustn dustn is offline
Poor Student
The knob is a timer... Thats a timed charger for 7.2v r/c car batteries. I wouldnt entrust it to a bit. Yes, auto peak charge is possible, just search for "peak charger" or somehting. Tekin, Novak, and Indi come to mind as good brands. Make sure that you will be able to adjust the output amps on them, down to in the mah range, mine goes down to 500. It worked with my regular dual cell, but didnt work on my layman's dual cell. I think 500mah was too much for the lil batteries.
Fight Crime <--> Shoot Back
Old 02-26-2003, 09:36 PM
Namuna's Avatar
I suppose if you stuck it up Brian Johnson's buttocks, it could?
Will this Charger work for Li ions? chooch XMODS Mods and Projects 1 12-12-2004 11:40 PM
car won't work off charger Bit Char-G R34 Bit Char-G / MicroSizers 2 12-10-2003 12:21 AM
Duratrax Piranha Peak Charger help jkellington Bit Char-G / MicroSizers 2 06-16-2003 03:33 PM
Peak Charger? vwarner Bit Char-G / MicroSizers 0 11-05-2002 04:24 PM
