Old 02-14-2003, 02:11 PM
andrew andrew is offline
my steering stopped working and i have no idea why
Today after I installed my new black rims set, a new motor, and rare earth magnet on my Bit Char-g my steering stopped functioning properly. The magnet still responds, but when the front end is completely assembled the most I can get from the steering is a very minute twitch. The motor responds perfectly, everything is fine except for the steering.
I have double checked all the wiring and connections and everything seems proper, and like I stated earlier the magnet still responds. I've tried using the original stock parts with the front end, axles and all. Same results, a barely noticeable twitch.
What the hell is going on? I have no idea what to do next, any help will be more than welcomed And I will supply any pictures if needed, thanks again.
Andrew
PS - If it makes a difference I removed the sway bar some time ago, but even then the steering still worked perfectly prior to today's "upgrades."
Old 02-14-2003, 02:24 PM
Hatchet_Dan's Avatar
Hatchet_Dan Hatchet_Dan is offline
Juggalo Bit Drag Racer
Send a message via AIM to Hatchet_Dan
did you make sure......
1.the magnet is in there pefect strait
2. the nuckles are in the steering thingy the right way?
Old 02-14-2003, 02:28 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Retarded Stunt Driver
my hunch is the magnet is backwards.flip the polarity and i bet it works fine.
Old 02-14-2003, 03:00 PM
thanks a lot hogjowlz, that was exactly the problem. I totally forgot about testing the polarity, even when the article at QFM specicially mentioned it.
Thanks again!
Old 02-14-2003, 04:57 PM
DOPE! i jsut took apart front end of my s200 cuz the magnet fell out and it was doing same thing lol
Steering stopped working Antimatter ZipZaps SE 1 04-26-2006 01:49 AM
HELP! Panther stopped working Dougman Combat Digi Q 4 03-29-2004 09:02 PM
my car just stopped working!!!! help!! rb26nate XMODS 3 01-04-2004 06:10 PM
Bit stopped working after replacement rexdale_hacka Bit Char-G / MicroSizers 28 04-30-2003 03:59 PM
