Old 02-11-2003, 12:15 PM
batesjm's Avatar
batesjm batesjm is offline
My Alter Ego Is Retarded
Possible third channel?
I know that this would not be an actual third channel, but it could function as one. Here is my question, If i were to ground the motor to the ground on the Pcb I could use the hot wire for going in reverse to power a seperate motor that is also grounded to the pcb. Is this clear enough or should I elaborate?
I like Pie
Speed Channel Website KingFuzz Miscellaneous Discussion 0 01-19-2006 04:12 PM
4 channel controller in question Blue Bit Bit Char-G / MicroSizers 0 11-11-2002 04:56 AM
Z Cars at Discovery Channel Stores puppyfriend Bit Char-G / MicroSizers 1 09-27-2002 01:36 AM
InsideRC on Outdoor channel Ohm Miscellaneous Discussion 1 09-13-2002 04:53 PM
