Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Combat Digi Q
Old 01-31-2003, 07:17 PM
Flawed-logic Flawed-logic is offline
Tank stopped charging
My tank stopped charging . worked fine untill a couple days ago... Now, when I try to charge it, the screen displays the charge CH and red dot for a moment (like half a second) and then blanks and displays the CH with the green LED, and does not charge at all... (leaving it on with the green LED does not let it charge).
I am doing the following for charging (maybe I am doing something wrong?)
turn off tank.
turn off controller
middle switch bottom position
Put tank on charger
turn on controller.
No workie . Any ideas?
L:F
Old 01-31-2003, 08:35 PM
GTR's Avatar
GTR GTR is offline
Bravely Runs Away Away!!
if your transmitter batteries are too low, it'll charge for less and less time...until it doesn't have enough voltage to charge it at all
the way it determines a full charge is comparing the voltage in the transmitter batteries and the tank itself. so....if they're both at a low voltage....no worky worky get it?
or...if your tank is already charged, and it won't charge, just leave the tank turned on. since the tanks broadcast their presence to the controllers, it'll eventually drain it's battery. that's how i keep my battery drained so i can get a full charge the next time
Old 01-31-2003, 11:48 PM
mcap27 mcap27 is offline
It is the batteries, same thing happens to me. Get fresh ones and you should be fine.
Old 02-03-2003, 05:40 PM
Cool that was it
L:F
My car stopped Charging! moxman Bit Char-G / MicroSizers 9 01-13-2007 12:20 AM
Help Needed: Tank Charging Builder Combat Digi Q 5 03-03-2004 05:57 PM
Fix for tank with poor performance Alard Combat Digi Q 11 09-12-2003 11:17 AM
Is my tank dead? Halthek Combat Digi Q 3 05-17-2003 04:11 AM
