Old 01-12-2003, 11:30 PM
powerhungry powerhungry is offline
Best way to mask for painting
What's the best way to mask these little cars when spray painting the body?? I have some paint for my old TAMIYA r/c cars.. I tried painting a couple of bodies and they just bled right into the windows.. it sucked! I used regular masking tape.. is there anything else out there that will work betteR?
Old 01-14-2003, 12:55 AM
frizzen frizzen is offline
Tool User
If I remember correctly, most of the paint masks they use on larger scale lexan bodies are vinyl.
So, the cheap easy way would be to apply electrical tape over the windows, and cut to size. Chances are, since you're customizing you already have some lying around.
Other than that, you could go buy some of the good quality masking tape. (not exactly cheap, and you probably don't have it)
Old 01-14-2003, 10:28 AM
I think i'll pick up some of that tamiya masking tape... The one i used was hard.. maybe that helped in the leaking since it didn't "conform well" to the small shape. Thanks
Old 01-14-2003, 02:33 PM
payaso payaso is offline
BIT PIMP
If your having trouble with masking tape, then try this stuff..
Old 01-14-2003, 06:05 PM
arceeguy
Maybe you can use some self adhesive vinyl (cut in your design). I get mine from a local art supply store to make decals for 1/10 scale RC bodies.
Old 01-15-2003, 01:40 AM
johnrtse's Avatar
johnrtse johnrtse is offline
Payaso is right!!! Liquid masking products rule. Microscale aslo has a similar product available at most hobby/model shops.
Use this stuff and say goodbye FOREVER to bleed thru!!!!
John
"It takes a Mopar to catch a Mopar!" - Vanishing Point
Old 01-15-2003, 10:40 AM
I used the Tamiya tape and it worked great!!.. only problem is now.. I used spray paint to paint the car.. (Metallic Blue pactra brand) and it's not too shiny.. how can i get this thing shine??? use some clear coat?? or do i use some rubbing compound to shine it up?
Old 01-15-2003, 11:30 AM
tinyrc's Avatar
tinyrc tinyrc is offline
FYI we'll soon be offering pre-cut paint masks for most bodies in the Shop!
Old 01-20-2003, 04:58 PM
elliot216 elliot216 is offline
Send a message via AIM to elliot216
How soon is "soon", Tiny RC.
DUCKBILL mask contest results bren For Sale/Trade 0 06-05-2006 08:16 AM
what is a mask badboy727 XMODS 10 12-16-2003 03:36 PM
