Hi there
I've had a bit of a search on the forum, and i can't see if anyone has found a solution.
I just got a 3.0 motor from QFM - my problem is that sometimes my bit will get stuck if i stop. Quickly going in the opposite direction will then seem to "free" it, and it'll go again.
I've taken a good look, and it looked like the motor gear is not quite meshing - i've solved this by adding a very thin bit of plastic to move the motor closer to gears. This stops the gears sticking (they run nice n smooth now
), but it still stops occasionally.
(BTW - i am using the right gears
Is there anything else i can try? I've tried changing position with screws at the back, lubing anything which moves, etc - is there anything else like "running the motor in" (whatever that means)
Thanks
