01-02-2003, 12:27 PM
no power! help!
hi guys,
can anyone help me with this? when the car is on the controller, everything works. when removed after a full charge, nothing works.(no turning and no motor power)
Bit gurus - help!
______________________________
Automodelista: 3.8, 150mah, spring sus.
Wild-G: Raise Tiger w/3.8@the wheels & 2.2@the plow, 150mah
Lancer EVO: 3.0, 150mah, drift set
Hummer shell: 3.8, 150mah, spring sus.
01-02-2003, 12:51 PM
im guessing one of 3 things. your controller batteries are low, your car battery is dead or one of the power wires came off.
01-02-2003, 05:31 PM
Bit Obessed...
there's something wrong with the battery in the car. Since when the car is on the charger, power goes directly from the controller to the car and the car's battery, so when you take it off, the car's battery is not giving out a charge so the car doesn't work. The battery could either its loose, the battery wires are screwed, or if you took the battery out, it could be in backwards.
