Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer Parts and Hop-Ups
Old 01-22-2003, 03:44 PM
2000-redrider 2000-redrider is offline
a whole lot of shaking.
Does anyone else's DRR shake violently after putting on foam tires (for DTM)? Mine will rattles so much I think it's actually hopping up and down. It probably has to do with the foams not being trued, because it doesn't happen when I run the stock tires (rubber). So do you guys true your foams or is there another fix?
Old 01-28-2003, 01:34 PM
MicroRCEngineering MicroRCEngineering is offline
nomotorlimit@hotmail.com
that's normal. even DTM SP's do that with foams. Too much grip.
Endless possibilities with the ABC's
Old 01-28-2003, 03:52 PM
Tch0rT Tch0rT is offline
I have ABC DTM-SP foam tires on my DRR and it only shakes when I turn sharp while going fast. Sometimes it'll shake after I smack a wall going fast and won't stop until the DRR fully stops.
Ryan
Black NSX GT1 Dynamite Rocket Racer
7.2v BLiND Batteries Battery Pack http://www.blindbatts.com
HPI Micro RS4 Mod 45T Motor
HPI Micro RS4 14t Pinion
ABC DTM Bearings
ABC DTM-SP Foam Tires
Dynamite Aluminum Body Posts
Foam Insulation Home Made Bumper
31MPH or 50 km/hour
Green Lamborghini Murcielago MicroSizer
Rare Earth Magnets & Steering Spring Saver Mods
Old 01-28-2003, 10:09 PM
dtmracer dtmracer is offline
try rebuilding your diff. with the amount of grip foams provide, the diff can cause you to veer one way or the other on acceleration.
Old 01-28-2003, 10:44 PM
Hello DTMracer,
I end up rebuilding my differential weekly (sometimes more than that). It does pull to the side.. if I floor the throttle it still spins out a little even on low pile carpet with the foams. I am missing a few of the balls for the thrust bearing does anyone know where I can buy just the balls without buying a whole new 3 x 8 Thrust bearing package?
Ryan
ABC DTM Bearings
31MPH or 50 km/hour
Old 01-29-2003, 01:51 AM
fastboy fastboy is offline
im a micro daddy...
Send a message via Yahoo to fastboy
i assume your car is fully ballraced and that the foams are glued on?
if you dont glue the tyres they can expand and cause the wheel to oscillate.
Bought an Ebay lot of parts... will make you cry Jazz32 XMODS 17 07-08-2007 05:01 PM
xmod lot for sale! look! supraking91 For Sale/Trade 6 07-13-2004 02:02 PM
xmod lot look! supraking91 XMODS Gallery 1 05-10-2004 12:57 PM
Zip Zaps & parts as a lot. All new. Grampa For Sale/Trade 9 06-23-2003 07:48 AM
Ms/Bit clone lot ruddfan For Sale/Trade 6 05-03-2003 03:48 PM
