12-17-2002, 05:26 PM
tech question? help please
i have a initial d bit charg.. 1.0... 27mhz
my car is much slower than my freinds 1.0 cars(bit charg)..
also.. my car dramaticly slows down if i am going foward and turning at the same time.. anyone else have this problem?
remedy?
also..
i have a 3X5 oval track.. what is the highest motor i could run without flippin over all the time?
thanks
jim
jimerone@yahoo.com
12-17-2002, 06:53 PM
I are smart....
If I remember correctly, it's pretty much agreed upon that not all cars are built the same. Some are faster, some are slower. You must be one of the unlucky ones.
As far as the motor questions, that's a little harder to answer. How about buying all the motors and trying it out??
12-17-2002, 07:13 PM
That sounds like ur batteries arent that good. my car only does that when the A. Remote battery is bad or B. the car battery is bad. try replacing the remotes AA batteries and if that doesn't work then get a 150 nimh battery for ur bit. hope that helps.
12-18-2002, 12:13 AM
I process, therefore I am
Yah, sounds like you just need new batteries in your controller/charger. When the juice in the car gets low, you have less power for turning and moving at the same time. The steering coils have a very high internal resistance and draw all the juice from the motor.
