Old 12-14-2002, 10:29 PM
1llusI0n 1llusI0n is offline
BitOnline GM
Send a message via AIM to 1llusI0n
Serious Problems!!!!
Hey guys i just got my bit, it is a tomy and everything, a white skyline on 27. Ok i opend it up and the range blew nuts so i undid the knot under the board and it still didnt help, i tried to do the pot thing also but it didnt help one bit. What should i do, im very scared.
Old 12-14-2002, 10:30 PM
aero aero is offline
What It Is To Burn!
this is normal!!! try redoing the antenna with either cat5 cable or a solid copper cable about 6-8 inches long.
So Tell Me, What's The Price To Pay For Glory?
Bit Char-G Fairlady Z 57Mhz (2-Speed), 3.5 or 3.8, 150mAh NiMH, Blue Gears
MicroSizer RX7 27Mhz (Originally a 27Mhz Celica) (Injured Reserve)
ZipZap Supra (Originally a 49Mhz 911), DKS 2.8, 150 mAh NiMH, Red Gears
Old 12-14-2002, 10:31 PM
MicRoMaN's Avatar
MicRoMaN MicRoMaN is offline
Microman to the rescue!!!
You can try the Cat5 mod or the Telescope antenna on your controller. I think that those would help, you probably already know this but you can check out www.questformadness.com
**EDIT**
My bad, didnt know aero posted already, must of right before i did
-----My Mini R/C Site-----
Old 12-14-2002, 10:38 PM
BitOnline GM
Where can you get cat5 cable?
Old 12-14-2002, 10:40 PM
What It Is To Burn!
home depot, radio shack or a local computer store.........its also category 5 network or ethernet cable or CAT5....
Old 12-14-2002, 10:42 PM
BitOnline GM
so you use that huge cable or do you strip it and take a wire out of it?
Old 12-14-2002, 10:45 PM
What It Is To Burn!
strip it and there are 8 wires inside, just pick one. you can also double them up for increased range, but it adds extra weight to the back of the bit.........are you good at soldering???
Old 12-14-2002, 11:08 PM
BitOnline GM
Yes i am decent
Old 12-14-2002, 11:09 PM
BitOnline GM
Although should that work?, and i adjusted the pot alot i think.
Old 12-15-2002, 12:13 AM
rockfshr rockfshr is offline
I have some wire for sale that works great and looks good check it out if your interested.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3100018033
Old 12-15-2002, 03:57 AM
Ripper720's Avatar
Ripper720 Ripper720 is offline
Assembling a CLONE army..
Is it Cat5e? 2$+1$shipping=3$ for a small scrap of cat 5e?? What a bargin!! Perhaps its solid gold wire...
RIP
Problems W/ Skylines? awol12 XMODS 27 10-17-2005 04:49 PM
Any new (serious) companies making bits? SuperShot Bit Char-G / MicroSizers 23 01-01-2004 09:27 PM
Have you had problems with your 2.8 or 3.4 motors? NatakuARN ZipZaps 3 05-23-2003 05:26 PM
Problems with R-Specs... Vyrus bitchar-gmotors Customer Support 6 02-27-2003 02:02 PM
Problems with UK customs? GSXRMovistar Bit Char-G / MicroSizers 6 10-23-2002 03:35 PM
