10-07-2002, 06:15 PM
BitLeague STAFF
Cripple Cap Mod
Hello,
I just got a new Supra from Hong Kong, and the range sucks. I decided to open it up to find that it did not have a cripple capicator in it. I was wondering if there was a new way that they are making it, or if I have gotten a crap controller.
Xmods Honda Civic. Mixed body-kit
10-07-2002, 06:17 PM
BitLeague STAFF
BTW
BTW the inside of it is dirty and it has a white substance all over it I don't know if this is normal or not, but I don't have a camera so I can't attach pics. My max range is maybe 3 feet before it begins to stutter.
10-07-2002, 06:29 PM
BitLeague STAFF
BTW (again)
I tried swapping motors from my 3.0 to a 1.0 and it seems to work fine, but I don't really want to spend more money on a motor so does anybody know a way to fix the stuttering problem?
Thanks,
Yaksha
10-07-2002, 07:55 PM
It's super useless!
Bit Chars Supra onward don't have the inside the controller crippler, their crippler is in the car on the PCB. I had a hard time taking it out. See questformadness, they tell ya how. I untied a knot found below the PCB belonging to the car antennae and I gained 1 feet yay!!!
12-14-2002, 10:39 PM
JUST BRING IT
Yaksha,
try this,my supra had the crippler on the other side of the controllers circuit board.it was a #8.i wasn't really sure if it was it or not but i crossed my fingers and cut it,BINGO. my range was great after that. also, if you want try to make a small hole in the hood of you bit (like where a real car antenna would be) and run your antenna through there it makes your antenna a little longer,maybe gain a foot or two in range.
12-14-2002, 11:33 PM
Bâshbad the Wicked
After you untie the knot, why don't you just run the wire out the back since that's the side of the PCB that the wire connection is on instead of running it to the front and through the hood??
Stay out of the DAYLIGHT!!!
12-14-2002, 11:48 PM
JUST BRING IT
for me it was more for looks you know something different.i found out after that it help my range a little.
12-15-2002, 03:38 AM
hold up there how did you increase the range exactly i feel my newer microsizer is the same as yours and my range sux!!!!!!!! pics or anything would help tried untieing the antenna did help alittle.
beat your turbo brick
