Old 12-26-2002, 10:06 AM
rpm3j rpm3j is offline
Lightbulb Digi-q style dual motors with Bit PCB?
Is it possible to rewire a bit char-g to run dual motors with differential steering, like in digi-qs? Dual motors by itself isn't difficult; you just need to wire two in parallel. But how can steering be added in to slow down the L and R motors using the L and R output from the PCB? I suspect the digi-q uses a different style PCB with 2 speed controllers, but if it is the same PCB as found on www.tapspring.com, it would be as simple as finding a diagram of how the digi-q is wired. Does anyone know if this mod is possible? Thank you.
-M.
Old 12-28-2002, 11:46 AM
t-squared's Avatar
t-squared t-squared is offline
Bit Obessed...
you can try doing what I did to my canned heat, but the bad thing is that you have to control the motors independently, so that means you can press forward and back, but each motor has its own forwards and back.......
Anyways, what you can do is rewire it so that L/R control one motor while F/B controls the other.
Oh, and another thing is..........you might have to check to see if the L/R gives as much power as F/B.........
Old 12-28-2002, 11:48 AM
t-squared's Avatar
Bit Obessed...
There's another thread that I just noticed.......
http://www.tinyrc.com/forums/showthr...&threadid=5078
PCB Not working (Strange Dual battery symptoms) kenny_dilger Bit Char-G / MicroSizers 0 12-16-2002 10:59 PM
Need to Flip PCB for a dual B mod? ejaf ZipZaps 6 11-24-2002 10:15 PM
A New Way To Charge Single And/or Dual Battery Bit Char-g!!~! BaY oN AiM Bit Char-G Mods and Projects 7 09-12-2002 06:19 PM
Digi Q control conversion for BIT CharG slotsurfer Bit Char-G / MicroSizers 11 05-23-2002 09:55 PM
