List of best upgrades for Rocket Racer
I want to start a list of the best hop-ups and mod's for the Rocket Racer.
Hop-Up's
1. Foam tires- increased traction, better handeling
2. Foam bumpers- buy the front one and make the rear one out of foam and glue it to the back of your car BODY, so that it doesn't reduce the cooling of the motor as bad.
3. Rechargeable batteries- get the 6cell pack made for the micro RS4 and cut out 2 cells until your driving skills increase greatly and add cells as needed, not to excede 7.2 volts.
4. 180 size motor- umm speed, duh
5. 11 tooth pinnion gear- best gear for most tracks shorter than 10' on the longest stretch.
6. Ball Bearings- eheh, speed, controle, speed
Mod's
1. INTOE ADJUSTER- (still waiting for parts) order a "upper stearing rod" and remove the solid bar that conects the front wheels together and place the stearing rod in place of this and adjust to achive ideal intoe. You may need to get a new threaded rod and replace the stock one to get more length out of the bar. I found them in the RC plane section of my LHS.
2. Soft body clips- simple and stupid but I am seeing more and more pics of guys cars with the littl body clips on 'em. Take some fuel tubing from your LHS, cut a small piece about 4mm wide and slide it over the post. they even come in colors....
