Go Back   TinyRC.com > 1/24 and Smaller > Mini-X > Mini-X Parts and Hop-Ups
Old 03-08-2004, 03:53 PM
cdog4w's Avatar
cdog4w cdog4w is offline
newbmaster
shaft mod with belt xfer vs. gear xfer?
I've been looking at doing a shaft mod to maintain 4WD with a normal motor. I've almost got all the parts I'll need, but I've been thinking about the aspects of it that bother me. It seems most mods like like this have used a gear transfer, and it is usually pretty tricky to line up the gears properly. Even if you get the gears to line up, theres no guarantee that the next motor you try will. In the meantime I was trolling the xmod forums again and saw this post.
http://tinyrc.com/forums/showthread....threadid=18471
I was wondering what you mini-x people thought of doing a belt transfer instead of a gear transfer?
So aside from not worrying about gear mesh, you could also play with the pulley size ratios much easier than with gears.
The disadvantages would be potential breakage and belt slippage. Can you think of any others?
EDIT: Any idea where to get the pulley parts? The referenced thread used a VCR repair shop... are there any rc airplane parts that might work?
My rides:
Old 03-09-2004, 03:44 AM
Real Cars Suck
Pulleys have more rolling resistance than gears. An xmod would get some benefit because of the slip. However, you have a better system with a car that has ball diffs that are made to slip.
Realize also most belt systems in larger r/cs use pulleys with teeth so as not to slip.
Pulleys are used sometimes to make a more accesable drive train. That is there only real benefit.
I would think two larger plastic pinions (15-16 tooth) would be your best bet. Plastic ones from like an rs4 or a m18. (they should fit on a 130 and 180 shaft.
Old 03-12-2004, 08:38 AM
Cian's Avatar
Cian Cian is offline
Got Cheese?
Saw this on Mini-z-bar....
http://www.mini-z-bar.com/page043.html
Lisa: And vice versa...
Old 03-12-2004, 12:54 PM
cdog4w's Avatar
newbmaster
Thanks for the link. That guy's conversion car has been linked before and is just awesome.
My rides:
Custom Crawler Gear Mod hartoy53 ZipZaps Monster Truck 3 06-30-2008 02:44 AM
4th gear mod help hothotheat ZipZaps Monster Truck 3 03-28-2006 10:25 PM
4WD shaft mod + 180 motor mount cdog4w Mini-X 17 03-23-2004 06:46 AM
Bit Racer gear mod 323iT Bit Char-G Mods and Projects 7 01-26-2003 09:12 PM
