Old 12-01-2002, 10:15 PM
webgalo
Question speed
I would like to know what the speed of microsizers would be. And other thing, how much does the 2.6 engine improves that speed?/
Old 12-02-2002, 12:34 AM
mustang_steve's Avatar
the "too many tires" guy
a stock microsizer is just about walking speed, but its fast enough to get you in a bit of trouble with the car. spinning out isn't very hard to do. the 2.6 gets it to a bit faster than a walk, and gives it even more chance of spin. You also lose torque, since in electric motors you cant have both, you have to trade off.
The 2.2 is an excellent flat track motor though, and hte 2.6 is great for tracks with longer straightaways and less hard cornering. The more hard cornering you do, the slower motor you'll want. Now for oval track the size of pool tables, go with a 3.0 at least, a 3.8 is tricky, but can be done and will give you excellent results on a track of that nature. But at 3.0 and higher you risk flipping out instead of spinning since hte car is moving so fast.
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
speed speed speed ml22 Bit Char-G / MicroSizers 6 03-14-2003 12:27 AM
2.2 2 speed vs 2.6 1 speed eman1 Bit Char-G / MicroSizers 0 12-16-2002 08:34 PM
