Old 11-22-2002, 06:04 PM
SuperShot's Avatar
SuperShot SuperShot is offline
Heat sink fastening
One of my new bits either came with a broken rear body mount, or I broke it while doing the initial assembly. It cracked down the middle.
For the body this isn't a problem, but the heat sink for the motor, which presses up against the fastener, flys off when I try to attach it now.
Has anybody else experienced this? What is the best fix? I got the car from Tiny, but since I'm overseas, I thought I'd try fixing it before I ask about warranties.
Old 11-23-2002, 10:44 PM
dhdsf dhdsf is offline
I would have thought Araldite or any other 2 part epoxy would be strong enough assuming you mix it with slightly more hardener than resin??
Dave
- Skyline GTR set
- 2.6 motor
- Blue gears
- Medium soft all round
- Cat 5 aerial mod.
- Crip cap removed in controller
Old 11-23-2002, 11:32 PM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
Er, I just use a piece of strong paperclip myself. Stick iit in a slot on the bottom, bend it around the back and shove it under the transfer gear axle on the top to keep the heatsink down. If you bend it right you can snap the body over the bend in the back
Old 11-25-2002, 04:20 PM
Aaronmamo's Avatar
Aaronmamo Aaronmamo is offline
Pro Tiny Rc Racer
I used packaging tape and it works fine
Old 11-25-2002, 06:13 PM
miniwrx's Avatar
miniwrx miniwrx is offline
Boost this!!!
Send a message via Yahoo to miniwrx
Is that the only purpose of the heatsink, keeping the motor down? I am asking because I noticed teh K.I.T. sets have 2 or 3 heatsinks in their kit.
mini
*Subaru WRX* - Rally decals, w/ 3.8
*Skyline GT-R* - 3.0 motor, soft tires
*Honda NSX-R* - Boosted w/3.0
*XaNaVi Hiroto Skyline GT-R*
*Toyota Supra* - 2.6 and fast as h*ll!
Marlboro Skyline - Pics soon!!
true looking aluminium heat sink rydzjunior XMODS 0 01-03-2007 09:40 PM
heat sink questions AE86 Toyota XMODS 3 07-31-2006 01:11 PM
FET Heat sink shorting with ESC Horshu XMODS 2 03-30-2005 08:23 AM
Heat sink source Tee Bee XMODS 2 11-03-2003 06:27 PM
Heat Sink??? STFU Tuning XMODS 15 10-23-2003 05:47 PM
