Old 07-22-2002, 12:07 AM
dvious1 dvious1 is offline
need help with my booster
help!!!
my booster (35 mhz) seems to go slower than my regular (27 mhz) bit. both have a 2.2 motor and the standard gears.
Old 07-22-2002, 12:41 AM
tinyrc's Avatar
tinyrc tinyrc is offline
dvious1, this is in fact how it is supposed to be. The idea is that you get more control for technical sections of the track, and then use the boost (which you should find to be faster than your other 2.2) on the straights etc.
Old 07-22-2002, 12:24 PM
thanks tinyrc.
do you happen to know what the ratio of the speed is between the the booster and the regular bit is?
i.e. a booster with a 2.6 motor will run as fast (w/o using the turbo button) as a regular bit with a 2.2 motor.
it seems like my booster bit is running like a 1.0 with a 2.2 in it.
i put a 1.0 on my regular bit and raced the boster with the 2.2 and they seem to be the same speed.
Old 07-22-2002, 01:24 PM
tinyrc's Avatar
I'm not certain on the lower speed, but the boost speed is supposed to equal a regular BC-G +1 on the motor. So a 2.2 on boost is equal to a regular with a 3.2, a 3.0 on boost is 4.0 etc. I'm not positive, but I think that the non-boost speed may be -1.
Old 07-22-2002, 03:21 PM
yuck.
in other words, i would need a 3.2 motor in my booster to keep up with a 2.2 motor on a regular bit.
that bites.
Old 07-22-2002, 03:26 PM
Azninvasian2002
Yeah, on the lower speed my Skyline is very slow, but with the boost on it is very fast. It also makes a weird noise on the lower speed. I just moved the button on the back of my 4 band controller so it's on boost the whole time.
Old 07-22-2002, 03:31 PM
Azninvasian2002
Originally posted by dvious1
yuck.
that bites.
That's only on the lower speed though. I keep mine on boost the whole time so with a 3.0 motor mine is much faster than my friends regular bit char-gs with 3.0 motors.
Old 07-22-2002, 07:25 PM
323iT's Avatar
323iT 323iT is offline
i love to boost but sometimes its more fun to drive around with my 1.0
can these 6 frequencies run together? 2 bits, 1 MS and 3 booster clones? eman1 Bit Char-G / MicroSizers 8 08-06-2003 09:20 PM
Strange Observation, zip zap red motor in a 1 cell bit booster, and in a tricell. Clint Bit Char-G / MicroSizers 3 03-20-2003 01:58 PM
Booster & 4-Band Experience Blue Bit Bit Char-G / MicroSizers 19 02-18-2003 09:04 AM
Alternate Booster Button! chelboed Bit Char-G Mods and Projects 7 02-11-2003 08:57 PM
