Old 11-16-2002, 08:51 PM
microsizer microsizer is offline
Send a message via AIM to microsizer
antenna question
Hi, sum1 told me that i could use a old telephone cord for a wire so i opend mines up took out one of the wires in it and i cut sum of the pastic from the wire so i could see the copper strand but i found a string in like cloth material, it runs through all of teh phone cord. well im wondering can i still use this.
Old 11-16-2002, 11:32 PM
any1 plz cuz im about to solder my antenna back on so i need to know
Old 11-17-2002, 12:12 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
umm....strange idea...
but just try it anyways....
you can always desolder it..no bigge
Old 11-17-2002, 06:43 AM
SuperShot's Avatar
SuperShot SuperShot is offline
The thread in the phone cord wire is there for strength. The purpose of it is to make the wire flexible and strong at the same time, so that your daughter can lie in the sofa twirling the cord all day without breaking it.
I wouldn't think a phone cord would be much of an antenna for a bit since it is way to floppy and would probably just trail along on the floor.
Old 11-17-2002, 12:16 PM
hmm so wat should i use cuz i need a antenna soon and i dont know wat else to use
Old 11-17-2002, 12:53 PM
and also where can i find a cat 5 wire? at radio shack? or can any1 else give me any good antenna replacemnt ideas
Old 11-17-2002, 12:59 PM
mikey-flies
Perhaps cat3 cable was meant by phone cord cable as that is what is now used commercially.
Old 11-17-2002, 01:09 PM
btw do they only sell cat 5 with the ethernet cable, or do they sell it separately too? and if so wher ecan i find it?
Old 11-17-2002, 01:53 PM
Acceptable_Risk Acceptable_Risk is offline
Cat 5 is ethernet cable. If you don't just have some lying around, it's probably not worth going out and buying one. Stop by your local (non-chain) computer shop and ask if they have a ten inch or so scrap of unterminated Cat 5. There's a good chance they'll just give it to you.
Old 11-17-2002, 02:05 PM
i got an idea bout the telephone cord, wat if i just take all 4 wires out of the telephone cord and take out the string and twist them together and just solder them liek that? will that work? just and idea
Old 11-17-2002, 08:34 PM
thnx guys for all the info on the antenna help i just soldered it back on and it works great!
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 09:38 PM
question re: dual cat5 antenna ejaf ZipZaps 4 11-26-2002 03:29 PM
Question about telescoping antenna mod...? SPEED QFM Racing Customer Support 2 10-15-2002 07:07 PM
