Old 11-10-2002, 06:10 PM
Johnaten
Thumbs up The perfect antenna Mod...for anyone
First I took the cover off the car, removed the plastic safety cover, undid the knot in the antenna wire........that in itself put more range on the little thing. As for the controller, went to radio shack, bought the smallest telescope antenna they had....which was 32" I think. Opened the rc controller, unscrewed the screw holding the antenna in place, thus removing the antenna. Put the new one in.......now the new one is a bit longer extending just a little to much out of the bottom of the controller....easy fix for the hobbiest in me with an exacto knife or even a razor blade.....just cut enough of the plastic off around the antenna area to fit it perfect. All I see of the antenna if the 32" extended part from above and a bit of silver if you look at it from below. This took me less than 10 minutes to do, no soldering, and it cost me under $5. Now it has a 20 ft radius....which is more than enough to race on a decent size track without losing your signal. This little toy has become a great pass time.
Old 11-10-2002, 06:22 PM
Steve's Avatar
Steve Steve is offline
zipped up tight!
yep, though this has been posted about 12 times before.
Old 11-10-2002, 07:21 PM
Johnaten
Yes I did find more postings of this very same topic elsewhere in the forum and I have seen other mods that differ. But in repeating this mod over and over it gives the newbies up to date info with more simplified instr.. Even if mine are not.....
Old 11-10-2002, 09:32 PM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
ahhh newbies can learn to search just like us it is way to covered any where they go your just trying to take credit for it if you were just tring to get it notticed you could have posted it in the same thread and saved web space
newbies search
hehe please
Track and Antenna Mod pics Robotguy ZipZaps SE 2 04-12-2005 01:01 PM
still another antenna mod chilli_mp138 ZipZaps Mods and Projects 2 02-04-2005 11:39 PM
help :( antenna mod :( crip. cap. soggyrice.mMmMm Bit Char-G / MicroSizers 3 03-17-2003 07:04 PM
Question about telescoping antenna mod...? SPEED QFM Racing Customer Support 2 10-15-2002 07:07 PM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 11:13 AM
