09-17-2002, 11:32 PM
lower your car with glue and sandpaper
Im going to try this out, it's an easy way to lower your car besides doing the mods on QFM and removing the sway bar
Get some poly cement or similar glue and apply lots of it to the tab where it holds the body on at the front of the car, let it dry, then sand the top of the tab down. This basically "moves" the tab down further, which will allow the body to sit lower.
i might do it with the rear as well, but ill raise it (apply glue to the top and sand the bottom)
09-18-2002, 03:56 PM
![[tT]Skyline's Avatar](image.php?s=d10b6e264aff7f30e0ac1d5965551a4a&u=484&dateline=1044749803) |
OR yo can just aply some soort of body kit. I made mine out of a plastic card I found in my wallet
Peace,
[tT]SKyline
09-18-2002, 04:57 PM
smoove operator
Sounds good chronic... let us know how you make out. Any pics would be good too.
09-19-2002, 12:59 AM
OK.. just a warning, do not attempt to do this above technique to lower your car  the clip completely snapped off.. anyone got any other suggestions as to how i can fix the front of the body to the car now?
Also, i have cut the front section out of the skylines body, and im going to mount an intercooler (well, a fake one   ) in the cut out part.. you know what im talking about i hope
im going drag since this has happened, atm the front of my cars chassis is just sanded down to the plastic box part surrounding the steering setup (where the clip USED to be glued on)
//Bit:
//40MHz R34 Skyline GT-R
Soft rubber
Cap removed in car
09-20-2002, 10:48 AM
How low do can you go???
Okay easy lowering mod which can be done in about 2 minutes.
Grab a bit of flat plastic of a simeler thickness to the bits front clip.
Place it on the edge of a table and offer up the front clip to it along a 'straight edge'.
Using the bit as a template draw around the existing clip with a fine pen or pencil and then cut the new bit of plastic out. Offer it up to the front clip and check for differences.(It should be exactly the same size as the existing clip, if its not file it down with a mini file until its done or use a really sharp knife to slowly trim it down.)
Next job is the most brutal. Take your sharp knife and remove the smallest part of the clip at the front of the bit (The narrow bit at the very front of the clip, not the bit where it gets wider).
Then glue the new bit of plastic to the bottom of the bigger peice of the clip. Slam on the body and you will notice that the front has lowered by about 2 mm.
Want to go lower, then use spacers between the Char-g's clip and the new clip.
MY Custom Bit Supra
Gold Springs
Teal gears
Fury motor
Large front wheels
Soft fronts, mid rears
Custom heat sink
Whip attenna
Advanced Mike Williams Light Kit
120mh Battery
09-20-2002, 11:16 AM
smoove operator
Thanks for the advice Tortoise-Licker... I was actually toying with a similar idea, pretty much along the same line. I was modifing the body instead of the chassis, taking that same thin piece of plastic and gluing it to the upper part of the slot opening.
09-20-2002, 06:58 PM
www.d1gp.com
useful info..but for me..too low is bad cuz i race on moderatly bumpy surfaces
11-06-2002, 04:52 PM
Pro Tiny Rc Racer
i AM EMABARASSED
hI,
i FEEL EMBARASSED TO ASK THIS QUESTION. i WANT TO TAKE OF MY BODY OF MY CAR. hOW DO YOU TAKE IT OFF.
11-06-2002, 07:04 PM
It's super useless!
OOT: Damm kwikbb, I love your avatar, I have that gut feeling to make a personal Mini R/C avatar cuz this one is my Gundam one  .
BTT: You know that you could simply file off the original tab and put a new one there. I think the glue technique is pretty simple, but its very messy.
Lemme go find the lowering body topic a few people has reffered to for more info, don't know why I was given the credit
there it is
http://tinyrc.com/forums/showthread....&threadid=2153
11-06-2002, 07:20 PM
smoove operator
Thanks d00kie, took a couple of versions but this was the outcome... maybe somewhere down the road i'll make some new one's.
11-08-2002, 05:33 AM
Pro Tiny Rc Racer
I bought my car from my friend
11-08-2002, 09:15 AM
BIT PIMP
Hold your car like this, and squeeze the front tabs lightly.... It will come off.
silla
11-08-2002, 09:45 AM
smoove operator
Hey Payaso, you have hairy knuckles too... LOL j/k
11-08-2002, 09:48 AM
BIT PIMP
Yep, it's a curse.... I'm 1/70 part monkey...lol
silla
