Old 12-23-2002, 10:39 AM
timisone
anyone have any ideas to make
a heat sink
Old 12-24-2002, 08:29 PM
Silent_NightR34's Avatar
Got Mini-z?
wat exactly does a heat sink do?...do u kinda think it would be better without 1 so the air get to the engine easier?im gonna try taking mine off and rn a few minutes and see what happends..
Old 12-25-2002, 11:43 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
ive seen people use wire and tie it around, but thats a hassle if u want to swap engines...
ive never done this, but id use part of a paperclip bent into an S shape.....make the top of the S smaller to hook on the metal rod, and then the bottom part, make the end of it sligtly pointed in the opposite direction so that it stays on the plastic tab...
the heat sink i belive is so that it doesnt get the plastic hot..although these motors never do since they are so small....but if u were running for 30minutes nonstop, theyd probably be hot then
also similar to heat shields or somthing similar in cars to where it blocks the heat from getting into the car, or near u..
Make your own composite sheets. bizzybody Bit Char-G Mods and Projects 0 04-05-2007 05:15 AM
i have some cool ideas for zz help me make it work guitarplaya3000 ZipZaps Mods and Projects 4 12-23-2005 04:34 PM
6 Volt mod test with video-Any ideas? jpaustin Bit Char-G Mods and Projects 9 01-30-2003 02:43 AM
