Old 01-19-2009, 01:45 PM
Skv012a Skv012a is offline
Die Casts > Dnano?
I'm sure most of the Dn owners played with this idea already (and shame on those who didn't), so I was wondering how such conversions end up looking and working? Thats the wheelbases available and axle widths? Thanks.
Old 01-23-2009, 07:19 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Not Die Cast, but fovea's got some plastic and Epoch bodies:
http://tinyrc.com/forums/showthread.php?t=23889
Old 01-23-2009, 09:02 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
the weight alone would be detrimental to the performance. your going to get less run time and much higher motor heat, potentially battery heat etc. as it all has to work a bit harder to move it all around.
i would stay away from die cast. there are ungodly amounts of plastic 1:43 lines to choose from.
Old 01-24-2009, 12:30 AM
fovea3d's Avatar
fovea3d fovea3d is offline
I noticed that several brands start making finished 1/43 resin models with very high quality of details (wipers, mirrors, antennas, grills), hence the price!
Here are a few:
Bizarre some nice historic pan cars/Le Mans here.
Look Smart
Neo
Spark
I hope the moderators won't mind since these are shop links. Please erase if necessary.
Now at that price better check carefully the dimensions before buying.
I guess only large size cars would fit (forget the compacts).
Also not your everyday Dnano body
EDIT: I just bought a Neo static model in 1/43 (Porsche 930 Turbo). Althrough it looks fantastic and to scale, it won't work, don't buy them for adaptation to a Dnano chassis! I thought the body would be made in some kind of light plastic like plastic kit cars. In fact the resin is very very thick and heavy, the body is even heavier than some die cast models. I am a little disapointed... well, you don't try you don't know Last solution would be taking a cast from that body and make a lighter version.
Old 01-24-2009, 03:10 AM
strbm
Hi
I love the Bizarre cars. Does anyone know how much they weigh
Old 01-28-2009, 11:23 AM
Are there plenty of regular production cars in plastic that aren't 70-120$ though? Toyotas, hondas, etc? My only knowledge are some cheap oversea knockoffs that don't even get a metal treatment, but there's no steady line or a way to find them/cars I'd like made.
Old 01-28-2009, 11:37 AM
arch2b's Avatar
ebbro has a huge line of 1/43. there are tons of 1/43 manufacturers...
Old 01-28-2009, 02:25 PM
Ebbro are die-casts though, at least last few I bought were. Same with AutoArt and various other good lines.
Old 01-28-2009, 02:30 PM
arch2b's Avatar
ebbro has a resin line.... a simple google search will answer many of the questions you've asked.
Old 01-28-2009, 03:36 PM
arch2b's Avatar
don't forget to search slot cars too! those are bound to be single peice plastic. here is a good place to start.
Old 02-06-2009, 09:36 PM
fraz fraz is offline
I've built/detailed a number of resin kits and they are really heavy too. The great part is in 1/43 scale they virtually make every cool car ever made. I thought about getting a couple and "thinning" them down. I am also sketchy on how strong they would be in impacts. The dNano does get going pretty fast you know
Old 03-09-2009, 02:51 PM
MacTuffer MacTuffer is offline
Hello, if you try it will work. Check this out.
The brand off the model...
And more cars....
Old 03-09-2009, 06:57 PM
arch2b's Avatar
can you please post more pictures of the other cars?
what manufacturer made those other bodies?
how are you mounting them?
Old 03-10-2009, 12:21 PM
Its al made in Japan. Here is the site....http://car-zone.seesaa.net/index-7.html
Enjoy.
Old 03-10-2009, 12:53 PM
arch2b's Avatar
could someone please provide some translated information on these bodies?
in particular, how someone would go about ordering them.
