Old 12-11-2006, 12:36 AM
bridgebolt bridgebolt is offline
drift set up
can you pls post your drift setup...
Old 12-12-2006, 04:45 PM
379 379 is offline
Bald rear tires, linoleum, 1100MAH AAAs and dumb luck. Occasionally, I can catch it mid-donut and do a sick powerdrift. Usually, it just goes around in some killer donuts that wont stop till you lift off the throttle.
In my garage, X-mods and Mini-Z are not competitors. Both get stuck just as easy, pull the same amount of weight and are equal on fuel. Why be picky?!
Old 12-28-2006, 08:26 AM
nismology's Avatar
nismology nismology is offline
drift wheels, carpet, 4wd goes sidways very well.
hopfully getting the stage 2 motors
Old 12-29-2006, 03:53 AM
drewdown84's Avatar
drewdown84 drewdown84 is offline
Send a message via AIM to drewdown84 Send a message via Yahoo to drewdown84
rwd or awd better for drifts?
67' Pontiac Firebird -> 6 Cell, Bodykit, AWD, RS Bearings, 4.5 Tie Rod With Blue Front Springs And Yellow Rear, Stage 2 Motor With 9/25 Gearing, Modded Light Kit, Drift Tires...
H2 -> 6 Cell, RS Bearings, AWD, Lift, Body
05' Ford Mustang -> Custom Tamiya Paint, Light Kit and thats it cuz it aint a GM... gonna get a 6 cell when my girl learns to solder...
Traxxas T-Maxx .15 -> Aluminum chassis parts... soon to get a custom light kit...
Associated RC10GT -> RPM bulkheads...
Old 12-29-2006, 11:53 AM
zzultimate zzultimate is offline
Send a message via AIM to zzultimate Send a message via MSN to zzultimate
Definatly awd is better. RWD is 100 times harder to drift with. If you don't have awd(which your sig says so :d ) get it. Drifting is as easy as turning once you have awd.
My setup.
For awd, I have obviously awd, batts front, rachargeable batts, stock tires, stage two, hardwood.
RWD, stock tires, batts in back, rechargeable batts, bearings, and stage one.
Xmods:
Old 12-30-2006, 04:24 AM
drewdown84's Avatar
i learned this with the awd vs rwd at work today...
haha... i took both my cars to work today... cuz i was gonna build the six cell there... but ya... its a bit more involved than that... so ya... but my awd firebird can turn in a tight circle like a forklift... and was just fun as heck to drift around with... fwds and bckwds... the CRUSTang was fun... but not as much... they were more powerslides than drifting... but still fun...
Old 01-04-2007, 04:42 PM
anticasper86 anticasper86 is offline
Send a message via AIM to anticasper86
awd
drft tires
wood floor
soft suspension rear
hard " front
SCION
4WD
yellow suspension front axle
blue suspension rear axle
drift tires
decals kit
stage 2 motor 9-25
reachargable rs batteries
NSX
rs rechargables
stage two white
body kit
foam tire
CIVIC
rs rechargables
AWD
body kit
metal bearing
stage two red
yellow front/ back suspension
tie rods
Drifting explained steelo Miscellaneous Discussion 5 07-14-2007 08:35 AM
Stock ZZ drifting? Elpizo ZipZaps 6 11-06-2006 09:04 PM
BCG Drift Set: Useful? ownzorzor Tips, Mods and Reviews 0 10-17-2003 04:49 AM
Drift Set? takumi_drifto Bit Char-G / MicroSizers 6 12-15-2002 11:43 PM
Wanted: White Drift axle & purple stab set QFM Racing Bit Char-G / MicroSizers 3 09-28-2002 06:34 PM
