Old 10-13-2006, 09:27 PM
zzultimate zzultimate is offline
Send a message via AIM to zzultimate Send a message via MSN to zzultimate
Zzultimate's AWD ZipZap Buildup
I'll start with a few pics. Pretty self-explanitory. The plan is to make an awd zipzap with the same demensions of the stock zz, and all fit under a zz shell.
I'm not actually using the zz chassis. It's for referance. You can see some u-joints and, a drive shaft, and slot car gears.
The almost compleated rear end(still same wheel base as regular zz) Drive shaft, and started front end.
Also going with the awd zz, is a custom truck body. A project in itself. I've started putting in a bed allready. Yet to come is a lightbar, brushgard, and a new paint job.
Update on the axles.
Xmods:
Old 10-13-2006, 10:01 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Looks like you are making progress there! What chassis are you using there? Keep it up!
Old 10-21-2006, 07:37 PM
Update on rear end
Xmods:
Old 10-29-2006, 12:48 PM
Xmods:
Old 10-29-2006, 12:50 PM
Body fits snuggly on it
Xmods:
Old 10-29-2006, 03:04 PM
RCdabbler RCdabbler is offline
Is that chassis material plastic or ?
Old 10-29-2006, 04:59 PM
Plastic.
Xmods:
Old 10-29-2006, 06:31 PM
I'm leaning towards using aluminum but I'm mocking it up in plastic for ease right now.
Your making good progress, much better than me but then work has been keeping me very busy/tired.
Old 11-08-2006, 05:29 PM
I really don't like the tiny controller of the zzse, so I made a new one out of a ssmt controller. I found it really easy, because I could use the same places where the ss board and componets were, to put the zzse's on.
I relocated the antenna, and used the same battery compartment.
Xmods:
zipzap and zipzap se? xmod456 ZipZaps 8 01-24-2005 04:11 PM
AWD questions Lucky7 XMODS 6 09-24-2004 10:46 PM
just went through my parts box....... airbob20 For Sale/Trade 10 01-25-2003 11:21 PM
Zipzap motor and PCB dtmracer ZipZaps 4 10-17-2002 05:01 PM
BItDra-G times recorded for 2.4v ZipZap QFM Racing Bit Char-G / MicroSizers 13 10-01-2002 09:15 AM
