Old 07-26-2006, 05:27 PM
aussiek2000
which motor kit?
what motor kit should i het. the kit with 1 motor and a ton of gears, or the kit with 4 motors. i have the evolution series g35.
1.http://www.radioshack.com/product/in...entPage=family
2.http://www.radioshack.com/product/in...entPage=family
Old 07-26-2006, 07:54 PM
Jazz32
If you have an evolution, you're going to want the set with all the gears. It's more expensive, but you can't change gearing otherwise.
The set of 4 motors is for the gen1 cars. It has 4 of the same motor as the evo set. You can pull the brass pinion off of one of those and switch the wires from an evo and use it just the same.
